RR Headlights Blinding Everyone?
donkey
California
So I got a weird one. My truck stock, the headlights were perfectly aimed. I added 300# of permanent weight in the back, and the headlights seemed like they autoadjusted just fine.
I then added new springs to the rear to bring the ride height to stock, which they did. I then did a ride height calibration in forscan lite.
Now my headlights literally point at the sky. I’m blinding everyone. I did a headlight calibration as well. I can manually adjust it, but I’m more confused what happened after the reset in forscan.
Anyone go through this?
dsmclark
Sam
Dorset
Ford Ranger Raptor
Mine would do the same, I ended up just adjusting them down. On mine it would sometimes adjust them wrong on start up as where I park isn't level
embedded rock
Earth
Someone else here had this problem. Seems like there was a forgotten load in the bed, and after removing it, the lights leveled.
Curious about a manual adjustment, this is what I see in the owner's manual. Still might be a manual adjuster present with these lights.
Ford Ranger RR Headlights Blinding Everyone? 1770039827166-g
pasali
Paul
Livermore CA
Carpenter
@donkey, this headlight calibration you mentioned, is that a forscan thing?
I am having similar issues.
donkey
donkey
California
Here’s the full sheet
Ford Ranger RR Headlights Blinding Everyone? IMG_9230
donkey
donkey
California
Yes, I reset my ride height level sensors. Also did a headlight recalibration.
Get Forscan Lite and an OBD MX+.
