Running board lights??
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
I need to install running board lights like I did on my F150 but I need to know if anyone has figured out which wire to tap and where it's located. I don't care for the amber running light/white entry lights. I just want white lights that come on/off with the dome light.
The F150 is under the right rear door kick plate. It's a grey/purple trace wire. Easy-peasy to install.
These work great!!!
https://www.amazon.com/dp/B0895SY1L...LPK&ref_=list_c_wl_lv_ov_lig_dp_it&th=1&psc=1
Cut in half and it's a perfect fit. With proper cleaning before install they will last long time. After 5 years mine never came loose and worked like brand new.
Thanks in advance for any help.
fordgt
Ford accessories website has a kit for bed lights that are triggered when the dome light comes on. The instructions are on the site. But it isn’t easy-peasy for sure.
pbouy
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
fordgt:
I think I've seen that one and they tie into the third brake light?? But I'll go check it out again.
They've got to get power to the back of the truck somehow. Just need the trigger wires. – Thanks
fordgt
It’s this kit
Ford Ranger Running board lights?? imag
pbouy
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
Thanks for that but I found what I needed. F150LEDs came through as usual. The only difference is that I clean the truck with acrysol very, very good. Then apply adhesive bond to the area and let it dry. As long as the strips have 3M VHB tape, they'll never come off until you take them off!!!
The 2 wires I need are under the kick panel just like my F150 but different colors.
fordgt
Just checked with F150leds customer service, they can’t say whether the 19-23 kit will work on a 6th generation. So if you would please photograph where you tap into the loom for the power and post it here.​
seems like when I was trying to do it and posted here, it was reported 5th & 6th generation were different.​
pbouy
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
I will check when the weather warms up a little and post it here.
fordgt
Thanks! I am in Florida, woke up to the end of a freeze warning and now it’s almost 70!
pbouy
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
I know. I'm in S. Louisiana and this was last year on our way to 6" of snow!!! Almost had the same thing this year.
Ford Ranger Running board lights?? 619251701_26422794787305431_4382985289187297545_n
fordgt
This is F150leds response
Ford Ranger Running board lights?? IMG_8149
Granite Stater
TX, USA
2025 Lariat FX4, 2.7
Operations Manager
Hey there, all. Curious if this project was done. I installed LED running board lights on my last truck tied in to the interior dome lighting to work as puddle lights (also had them as running lights and turn signals), and I'd like to do this to my new truck as well.
pbouy
pbouy
Paul
Plaquemine, LA
2025 Ranger XLT
Brian:
I've seen many kits online that do what you want to do. Here's a link to just one: https://www.amazon.com/dp/B0BSF4N2G...C9T7BMLPK&ref_=list_c_wl_lv_ov_lig_dp_it&th=1
I only want the puddle lights and not the running/turn signal lights. I just need to find that white/grn stripe wire running to the back.
Granite Stater
TX, USA
Operations Manager
Thanks, Paul. I have the same kit as I had on my last truck, just looking to connect to an interior light without having to run wire all the way to the cargo light again.
Thanks.
fordgt
Brian:
There is a white with green stripe wire in the bundle that runs through the passenger side under the trim between the seat and the door. I tried hooking my bed lights to it. There was power, but the lights were very dim. My friend who does auto electronics suggested it could be enough to trigger a relay. But I put a remote in my system and never pursued the relay idea. I did leave the red + wire in case I changed my mind.
Ford Ranger Running board lights?? IMG_8249
fordgt
Can you tap into the cargo light? I didn’t see any way to get wires up there. Do you have to lower the headliner? I realize they obviously got wires up there for the cargo and brake lights, but I couldn’t find it.
