Signature Lux Grill Lights
  • Thread starter Deleted member 9086
  • Start date
  • Watchers 6
patc890
Patrick
Rockville, MD
Received my Signature Lux grill lights. Well constructed flush fitting lights.
Simple kit and instructions. Provides two different hook ups, either via the Aux #1 wiring harness or Aux #2 fuse box.
Looking forward to installing them next week along with the Fog Lamps. Post more once installed.???
Are these the amber only lights or the amber/white ones?
Deleted member 9086
Mine are white, however you can get them in amber/white or amber.??
patc890
Patrick
Rockville, MD
Mine are white, however you. An get them in amber/white or amber.??
Thanks. They sent me both as I wasn't sure which I wanted. They also look different so I wan't sure which was which. So you said yours are white then larger ones are white? See my photos below.
Ford Ranger Signature Lux Grill Lights IMG_1317
Ford Ranger Signature Lux Grill Lights IMG_1316
jskrillz
johnny
Virginia
24 ranger raptor
There is an option in the instructions to do just that. Not complicated at all. I was on the fence and but went with Aux 1 as I’m not sure that I may want to “turn them off.”
I just leave aux 1 on so when I start the truck they are on.
Is aux 1 powered when the truck is off? For some reason I thought it was. I want to do the same but don’t want my battery to die when the truck is off if the lights stay powered.
BHunted1
Sumner County, TN
2024 Ford Raptor Ranger
No...... I leave switch 1 on... no prob.
If you are going to want at least the amber on always, run a line to the sidelights in the side of the front fender. Why waste a switch?
BHunted1
Sumner County, TN
These, (or any other market brands), look huge in the photo.
They actually fit nice in those upper holes? (first row above camera)?
Those holes are sort of diamond shaped inside and don't have a flat back surface....
BHunted1
Sumner County, TN
3M has an adhesive that is used on most of the Air Design spoilers. It’s black and sets very quickly. This same adhesive can be used on the rear of the lights when they’re set in place. It’s waterproof and holds far better than any silicone available.
It can be purchased on Amazon.???
Good stuff, but once it's on, you'll never get it off. bulb dies; it would be a biotch.
KReedRaptor
Can you share how you installed? I purchased the amber grille lights but they don’t seem long enough to reach the Aux box from the farthest point on the left. Did you connect all three wires to the aux box directly? Or do you connect them together before connecting one to the aux box? I am a newbie to this and the directions from Signature Lux are minimal at best. Any guidance would be appreciated.
Ford Ranger Signature Lux Grill Lights IMG_4784
patc890
Patrick
Rockville, MD
I ordered the amber/clear from them but because I wasn't sure they were nice enough to send me both. I started to install the amber which are not as wide as the multicolor ones. I found that they wouldn't fit very well. The middle one went way into the back and the side one were crooked/cocked. I gave up trying to install them and used the multicolored ones instead. These were also a bit of a pain. I ended up using superglue so I could get them to stay straight. I don't think these are designed very well.
As for your question when trying the amber lights I connected the grounds together with an extension piece and then to a bolt on the frame. I also connected the yellows together and an extension so it would reach the Aux 1 wire by the battery.
Thatch11b
Limerick PA
Very happy with mine. Fit well and are bright. I wired mine to the side marker lights.
patc890
Patrick
Rockville, MD
Glad yours are good. I would have liked to just have the amber ones. I wrote them about the fix but never heard back.
KReedRaptor
Thanks for the guidance on the install. I emailed Signature Lux and did not get any help.
patc890
Patrick
Rockville, MD
I'm surprised they didn't answer you or me. Their customer support seems to have a good reputation.
2wheelfish
OC Cal
Just received mine and they look like the amber ones with the short black and yellow wires. Pretty disappointing actually. Leads aren’t long enough, wiring is cheap crap, connectors don’t match each other, no real instructions. Just some random parts thrown in a bag with a couple generic lights. I’m sure I can figure it out, but I’ll need to buy some longer wire, decent connectors, cable sheathing, some proper adhesive, etc. Maybe I missed the memo, but I didn’t get the impression I was buying a DIY hobby kit.
