Sub Space Behind Backseat Request
cfm56doc
Tampa
2023 Bronco Sas (Hers), 2024 Ranger Raptor (His)
Jet engine field service rep
Without me having to pull out the back seat to take measurements, wodering if someone has the dimensions where the factory B&O sub is installed and others have installed say a Kicker Hideaway 8" or 10" sub. Not the wacky dimensions of the scroll and all, but basically the main rectangular area dimensions.
I have a Cerwin Vega VPAS12 sitting in the garage from a previous installation and trying to determine if it will fit where B&O sub is mounted before I pull the seat out just to find out if does not fit.
Thanks!
cfm56doc
Tampa
FWIW my CW subs dimensions are 13.5" Length x 11.25" Width x 3.0" Height
Buellsox
Scott
Tacoma, WA
Local 26 Union Plumber
A 12” sub on the back wall?! Man it’d be tight if at all possible. The big question could you get enough air space in the build for a 12”…..that’s the dilemma I could see. Be a crazy build if you pulled it off and still kept the back seat as is. I’ve redone my setup and a RF Punch 300.1 & Kicker Keyloc ate up all the space once the B&O sub was jettisoned.
