YukonRanger
Please don't take this post as criticism, just offering friendly advice:
Looking at the photo you can see that setup is unbalanced, the squat is far too much.
The truck should look level while hauling.
A safety tip is to try not to exceed 80% of your maximum tow capacity either. It can save your life.
You can also look at
Cheers from the north.
- Get a 1-2 inch lower drop hitch to level out the camper
- Try to shift some weight in the camper behind rear axle
- Don't shift too much, aim for 60% weight up front, 40% rear.
- Always give it a little swerve at a lower speed to test after shifting weight
- If it wants to sway, or the sway doesn't immediately correct, you went too far.
- Weight distribution hitch (looks like there might be one)
- air bags
- Timbren SES
