Transfer case internals
AlloyPony
Kentucky
'25 F-150 Lightning Flash
From what I have been told, on the F-150s with "auto" 4WD setting, only the Auto setting uses clutches to allow the center differential to slip. When the driver selects 4-low the transfer case actually becomes chain-driven and cannot slip.
This is different from how the 4-Auto transfer cases work on Ram and GM trucks. Those use clutches in ALL transfer case modes, and heat build-up in the clutches becomes a problem when using the truck in tough offroad conditions.
Does anyone know how the 6G Ranger transfer case will operate? Will there be options for a chain-driven (and therefore problem free) t-case?
AlloyPony
AlloyPony
Kentucky
Thanks for the link. Unfortunately it's still a bit confusing.
From the article linked there: "4L (4X4 LOW) – Provides electronically or mechanically locked four-wheel drive power to both the front and rear wheels for use on low traction surfaces, but does so with additional gearing for increased torque multiplication. Intended only for off-road applications such as deep sand, steep grades, or pulling heavy objects. 4L (4X4 low) should not engage while your vehicle is moving above 3 mph (5 km/h); this is normal and should be no reason for concern. Refer to Shifting to or from 4L (4X4 low) for proper operation."
Electronically or mechanically? Which is it? Lol.
I know that the clutch system on the GM and Ram trucks is very problematic with overheating issues. I've experienced it myself just last year on a brand new Ram tugging on a stuck vehicle for less than 30 seconds. I'm hoping the Ford system relies ONLY on mechanical lock-up while in 4-low.
Scooter
Vancouver, BC, Canada
65 Comet, 2011 Ford Ranger
--Machinist
Thanks for the info. I am alway's curious if the engineered systems work in the real world settings. Maybe finding out if the Ford system is better or worse then other manufactures.
NC Spuds
Greenville, NC
BMW X5, Lexus RC 350, GMC Canyon Denali on order
Seed potatoes
it’s both electronic and mechanical. The video in the referenced thread does a good job explaining it.
