RCMUSTANG
- First Name
- Ray
- Joined
- Jan 22, 2019
- Threads
- 2
- Messages
- 1,539
- Reaction score
- 574
- Location
- Los Angeles
- Vehicle(s)
- 1989 Mustang 2017 Fusion
65mm throttle body.
What???There are cheaper ways to remove weight.
For vehicle acceleration, wheels and tires are barely any different than the same weight anywhere else on the vehicle. The wheels accelerate slowly, over a long time period, and never really spin that fast. That means they can't store much kinetic energy from angular velocity and acceleration
100% falseThere are cheaper ways to remove weight.
That article is bologna designed to sell wheels. Anyone with any mechanical engineering or simple physics training know it is pure BS by this opening article statement:
Could go with a small ethanol blend, Or turbos.Would like advice on where I could pick up some additional hp. I currently have K&N kit, intercooler, down pipes, and a ZFG tune @ 23lbs. From what I have seen hot and/or cold piping isn't cheap and doesn't appear to add much at all. I also plan to have my tuner bring my boost up to 25lbs.
OkeedokeeI really don't care what anyone that does not understand basic physics thinks. This is true regardless of what they own or drive or who they are. If someone wants to believe in Santa Claus or the Tooth Fairy, that is fine with me. I work in reality, not fantasy.
There are certain fundamental ways things work. There are unbreakable rules.
The wheel is primarily doing two things. It is a rotating flywheel (ring) and also has to track surface irregularities. While tracking the surface is important for traction and handling, acceleration (the "horsepower" topic here) is concerns energy storage as the velocity changes. This is a well documented simple thing.
The rotational energy stored in the wheel is dependent on the angular velocity and the weight. The velocity is a square while the weight is linear (1 for 1). The angular velocity is proportional to the radius from center. Twice the radius (at the same RPM and weight) is four times the stored energy. Twice the weight is just twice the stored energy.
Since the tire tread is the furthest thing out it has the most angular velocity. If we look at the distributed mean weight of the wheel as being half way out and the tire as the outer ring, four pounds on the wheel is the rotational equal of one pound on the tire.
The very most a weight change could in horsepower load make compared to weight is two times the static weight , and that would be an ideal condition. You will be way less than that.
If a vehicle is 4000 pounds and has 400 HP that is a 10:1 ratio. 40 lbs static removed is like adding 1 HP so far as acceleration (assuming the traction is perfect). The rotational equivalent in a normal wheel is going to be twice that.
It isn't my fault that people writing wheel marketing ads are stupid or dishonest. Then the public swallows that bologna and spends $2000 to gain almost nothing.
Look at how smart bicycle racers are. They have to know these things because they are pumping the pedals:
https://www.bikeforums.net/road-cycling/628389-rotating-weight-vs-static-weight.html
