What Rear End Do North American Ranger Raptors Have?
sandbagger
2010 f150 Raptor
Tool And Die
The rear end sure reminds me of 9" does anyone know what the rear is classified as
JAC
CT
2021 JTM
^^ Is it the Dana Advantek M220 with the double-row ball bearing pinion bearing?
sandbagger
sandbagger
2010 f150 Raptor
Tool And Die
Thank you
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
Do you guys know if this is the same on the non-Raptor versions? If not, do you know what the Lariat rear end is?
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
IDK what model the lariat has, but I can confirm it isn’t even remotely close to what’s in the Raptor…
BigMeatsBronco
Allan
Oregon
self
incorrect information!!! I've already checked with spicer, they don't build it, Ford does, and it's likely built in Thailand.
Antman450
Anthony
Reno, NV
Does anyone know if the 2023 and 2024 Ranger non-raptor have the same rear end? I have a 2024 Lariat and would like to know if this is the same rear end as the 2023 Lariat.
JAC
CT
2021 JTM
FYI, I never said it was the Dana Advantek M220. I simply asked IF it was the Advantek. Nothing more.
Anyhow, the question still remains about what type of pinion bearings it has.
BigMeatsBronco
Allan
Oregon
self
Quinn at 74 weld has had one apart and says the rear is a full floater design
Bmadda
6gBronco, 4gBronco
Mechanic
Let's not spread any misinformation now, It would appear they ARE in fact a semi-floater. Quinn makes them full float by adding the portal box. Here's the parts diagram
BigMeatsBronco
Allan
Oregon
self
your right... I was mistaken, maybe he called it a unit bearing ??? ....I just looked back at his text and he called it a full floating berring...? looks fairly normal from the outside of the housing...anyways thanks for the diagram.
Bmadda
6gBronco, 4gBronco
Mechanic
referring to the wheel/axle bearing I assume? That definitely looks very different from anything I have seen Ford use!
