Will Fox "Tuned by Ford Performance" (2019-2023) Shocks and coil overs fit 2025 Ranger Lariat?
505Ranger
Elijah
New Mexico
2025 Ranger Lariat Fx4
Im looking for a good suspension upgrade and am having trouble finding manufacturers that actually make a shock set for the 6G ranger, but I've also read mounting points and parts are identical to the 5G or at least similar enough its compatible but yet not many manufacturers are saying that or confirming 5G shocks fit 6G, has anyone used this suspension on the 6G or something similar? If so how is it on the highway compared to stock or should I look at a different manufacturer? I want it for comfortable washboard road driving and some occasional desert running but need it to keep good on road comfort and manners, thank you. Also all work will be done through Ford or at least through a good dealer and installer.
Check here at American Trucks. It says it fits 19-25, which tells me 5G and 6G are close enough to the same geometry. Also, Bronco and 6G are on the same platform, IIRC.
hand-filer
Fred
The '24 rear shocks are outboard vs inboard on the '23 and older. I think the valving would be significantly different on the older model to control sway, given the increased leverage of being inboard.
dard6555
Ford Performance for 24-25 will be from Bilstien. Gotta wait a little longer.
