Wiring Issue
nmraptor
Albuquerque
BusinessOwner
Has anyone found an easy way to pass wiring from inside the cab out into the engine bay?
Sauce
Northeast
2025 Ranger XLT FX4
You need to punch through the bulkhead rubber gasket in the drivers side footwell. It’s not hard but takes a little finesse and ideally 2 people.
DutchRanger
Mark
Austin
24 ranger xlt fx4 2.7l
Attach wire to a un-bent coat hanger, using electric tape. Then punch through the rubber gasket.
BuenaRaptor
Erik
Vail, Colorado
2024Ranger Raptor
Estate Management
Super easy! The gasket is to the upper left of brake pedal from inside then in engine bay look in that same area and you’ll see a rubber gasket. I cut an ‘x’ in mine and have been feeding all sorts of wires thru haha. You can get to both sides but going from inside to engine bay is a bit harder. I just taped wires to a chopstick(cause that’s what it had!) and pushed it thru that way.
