yoopercharged
RRaptorscallion0331
Colin
Looks real nice but the price seems a little high ?
yea, they’re probably not the most budget friendly option out there. But personally I’m disgusted with the hack job antenna mount I constructed for my gmrs, so the brake light’s main purpose for me is that it centers my antenna up high, converts to nmo so I can throw on the midland ghost antenna and the Baja lights are my first non auxbeams so I’ll get to see what all the fuss is about there. I’m quite proud of my diy “sleeper” chase lights I threw together for about $120, which was my budget 5 months ago.
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0147
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0144
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0149
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0148
That f150 taillight is over 800 bucks????
Holy crap! They can keep it
RRaptorscallion0331
Colin
Hey @Goldylox22 my brake light finally arrived! Did you drop the headliner or just pry it open enough to hook up everything like a lot of others have successfully done? If you did drop it, what if any, video or instruction did you use? I haven’t pulled up the QR code yet but I know the YouTube guy flaberdoobin made a video where he dropped his. I’m just trying to get my ducks in a row before I start on the install.
this thing is heavy duty, and solid!
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
So I had it installed, didn’t do it myself cause I also had radio mounted in the center console and they had to run the antenna cable through to it. I do know they did have to drop the headliner for that specifically. Wish I could be more help
RRaptorscallion0331
Colin
No worries! My CB and GMRS are sandwiched in my glovebox and I’ve already ran coax to the back passenger bulkhead grommet. So I‘ll make it work, I appreciate you clueing me into this brand… stout construction and methodical wiring from what I can see.
Goldylox22
Goldylox22
Nick
Sacramento, CA
Self-Employed
Of course! I’d been aware of swarfworks for some time and when I went to get a third brake light these were brought to my attention by my Raptor run group. High praise from them and the fact the two bed lights point down into the bed instead of needing a third Baja designs s2 sold me. Spent 4 days out in Utah running it and it worked great!
RRaptorscallion0331
Colin
Install wasn’t that bad… ok maybe it was, but the improvement is 100 fold.
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0264
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0266
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0268
yoopercharged
RRaptorscallion0331
Colin
Did you end up dropping the headliner for the install?
Actually no, I only peeled it down a little bit and fed the wires through. I don’t know if the pictures capture it well but here they are:
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0252
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0261
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0258
Ford Ranger RAD Designs Third Brake Light Replacement installed IMG_0251
