2.3 MPC Fumoto Oil Drain Valve Extension?
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Went to install the F-137N Fumoto valve and found it it needs an extension. I didn't measure it before I put it back together so does anyone know if the 1/2 extension is enough to clear the oil pan?
BTW - I used this exact one on my 2019 2.3 and it didn't need an extension. I would use the adjustable SX version but I like the long nipple. Both were FX4s with skid plates.
Aircraft examiner
I ended up with the 107sx because i was worried about the issue you are having.
I bet 1/2 is enough though
T-Wrecks
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Did you use the plastic nipple? I'm wondering if that can stay on with the hose I plan to add.
Aircraft examiner
I did also get that. I havent had an oil change since install though
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
I had fumoto valves on all of my vehicles, they are good but I switched to Valvomax.
Aircraft examiner
I looked at those but thats to serious for me. I just wany to unlock the valve and flick the drain open
