2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd
Aircraft examiner
I heard that the 19-23 5th gen shackle lifts work on the 2024 and newer rangers so i figured i would try it out.
This is the kit pn you need:
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_124115
It doesn't come with bushing grease so make sure you have some before you pull everything apart. I have tons of packets from all the lift kits and lowering kits i have installed over the years but you can buy small packets like i have at your local autopart store. They are normally near the register
My 24 ranger sits dead level since i put a 2.5" leveling kit (spacer) on the front and i don't like it, i want a little rake in case i have to tow.
the wife got me a bds 1" rear shackle kit for my birthday, tuesday, from amazon and It turns out that if a person was so inclined, you could probably change the shackles in half an hour. i am not that worried about it so i drug it out and took pictures and stood in front of the heater because its 45 degrees and windy.
It looks great and the shackles are plenty solid, like one would expect. They are indeed angled exactly like the 6th gen ranger rear shackle and the hardware fits perfectly. This is good because its giving more options for mods for people down the road.
Here are the shackles laid out with the hardware and instructions. They are well packaged and the instructions, though generic, give you basic steps and importantly, the torques at the end.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_122053
This is the hitch on the stock shackles. I figured this is a great refetence point since its easy to measure from.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_122130
When you lay under the back, you will immediately notice the spare makes it impossible to remove the driver side shackle so go ahead and lower the down. While you are there, check the air pressure on it since its accesible. Its also a good time to clean and grease your spare hoist if you need to.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_123258
The stock nuts on the stock shackles are not very tight. I was surprised. I think i used a 3/4 socket and extendable ratchet to loosen the nut but you can do it with a normal ratchet. If you play with the jack, you can find where the height lets you easily tap the captured bolt assembly out with ease and maybe you can just push it, if you get it super close so there is no tension.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_123250
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_123300
Here is the bds and the stock so you can see the difference. The stock has one thin side with the bolts welded to it so they are not going to spin when you loosen the nuts. The side with the welds is bent and shaped to add stregth to the metal while keeping weight down. A common manufacturing process used in aviation and later in automotive parts.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_124057
Install the longest siver tubes in the frame bushings, one on each side. Put some bushing grease on them and just slide them in. If they try to push the oppsite side bushing out, while installing, jist put your hand over the bushing and push back and you will get everything together. As it gets to the last quarter inch, it will get tough so you can tap it in with a rubber mallet, use a long bolt with washers and nut to pull it together, or even a large pair of pliers with the washers will do it.
Then put your shackle and long bolt, washers, and nut in place to start reinstalling.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_125311
From here on out, its easy and basically just reverse of removal except you also need to put the tube into the leaf spring bushings. That part is super easy and you just grease it and slide it into the bushings as it wont try and push the other side out. After the tube is in, you will fiddle with the jack a little to lift the truck a bit and put the smaller bolts in place, along with the third tube. You will have to use one hand to push the leaf spring up to perfectly align the bolt hole to get the small bolt through everything but its super easy. After bolts are in, you tighten the nuts to get the play out and lower the truck down so its not suspended above the leaf springs anymore.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_153739
Here, you do the inital torqueing to 52 foot pounds on all 6 bolts. Of course, you torque the nut and hold the bolt head, both use 3/4" tools.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_133754
After your initial torque, you are supposed to jump on the bed or bumper to settle the suspension. I drove the half mile down to the ocean and back because the city doesn't maintain the road that well and it works the suspension way more then i could by jumping on the bumper or bed.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_135001
after setrling the suspension, you need to go back under and do your final torque to 76 foot pounds. Its a good amount of torque so its going to take some muscle.
Here is the hitch height after the final torque showing i got, basically, 1.5 inches of lift with the shackle install.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_135428
I am sure it will settle a little more over time. If i remember, i will measure at the 500 mile recheck of the hardware torque that the instructions say to do.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260131_134629
And now you done with your install and the truck looks great.
White willy
Earth
2025 Ranger
Told ya they fit perfectly,and will indeed net you an inch in lift.
Much better than a block for maintaining pinion angle as well.
Run a set of appropriate shocks,and money!
Aircraft examiner
Yup, perfect.
I didnt want to do the block since i have that rear sway bar kit that uses the ubolts to mount. I didnt want to be messing around with that stuff and the block
ryanO
Ryan
2025 RangerXLT
Sales
Awesome! Good to know. I am thinking of doing the lift with the Eibach front coil overs. This solution for the back end may work perfectly depending on how level the truck ends up sitting.
Is their an issue with using a block to get the lift over these shackles?
White willy
Earth
2025 Ranger
If you are a 2.3,you will be about a 1/4 to a 1/2 nose down once settled with out of the box Eibach setting.
Thats where mine was,but I also have the complete Rival skid plates,so you may be closer to actual level.
With the BDS shackles,mine sits an inch and 3/8 taller in the back.
Really an overall perfect stance for me.
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd IMG_0138
Aircraft examiner
No, you can use either and be fine.
I have an aftermarket rear sway bar assembly that mounted to the ubolts so i didnt want to mess with them
ryanO
Ryan
2025 RangerXLT
Sales
That is incredible! What wheel offset and tire size are you running?
White willy
Earth
2025 Ranger
Thank you,
They are 17x9 with zero offset,and a 285 General Grabber X3 tires.
White willy
Earth
2025 Ranger
Any rubbing issues you had to resolve? I'm looking at a 17X9 with a +12 offset.
No sir,none so far.
I have not had a chance to really flex it off road just yet,had a total knee replacement mid December,so still healing up.
Can’t wait to put it through its paces though lol
Aircraft examiner
Ford Ranger 2019-2023 5th gen ranger BDS rear shackle lift kit fits on a 6th gen 2wd 20260202_161940
After 350 miles of highway, city, back country roads, and one super long dirt driveway (almost a mile long). Oh yeah, and lots of speed bumps
Aircraft examiner
No, not reslly.
i kind of feel like the rear is smoother then it was but it could be my head
