2022-2024 Upgrade. Answer/Disconnect call buttons from the steering wheel.
Mooncat747
Rick
southeast asia
2023 Ranger Raptor 3.0
The 2022 through some 2024 models didn't come with the answer and disconnect call features. I think they were added in 2025. You can purchase the keypad and upgrade your RR to answer and disconnect calls from the keypad. Use Forscan to enable it. And no you cannot just enable the old model keypad. You must purchase the new keypad. So happy to have this now.
Bushmechanic
South East United States
I wish I could move all those Raptor buttons somewhere else and replace them with audio controls.
They're obviously important, but it's a bit of a silly place to put them.
Operating the audio system would be a lot safer from the steering wheel than the complicated, too far down to safely look infotainment system. You may as well be playing on a phone if you're operating that thing while driving.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Sorry, but I disagree. Love having the mode buttons readily available on the steering wheel at all times. Nothing worse than going through screen menus to change steering, suspension and exhaust sounds. I drive on a wide range of road surfaces and being able to change comfort settings on the fly is something I’ll never want to loose now that I have it.
I always use CarPlay and can control most Audio controls via voice or simple and easy to use buttons on the main screen. Screen for audio - steering wheel for vehicle dynamics (cruise control, gears, suspension, exhaust, etc)
RaptorME
Maine
I usually pick my audio source, usually Android Auto, before my drive then I can adjust volume and change stations/tracks from the wheel, nothing more I need that accessible.
Stoogey
Stuart
Hampshire, UK
2023 Ranger Raptor 3.0L V6
When you say enable it in forscan, is it one where you need to change the code or is it a preset option that you can turn on? Thanks
Mooncat747
Rick
southeast asia
It's both. APIM module and APIM asbuild, But some vehicles already have it enabled.
m3iaz
Michal
Poland
EU RR '24.5 3.0 BlueLighting 422HP
It doesn't worked for me.
BTW this AS Built codding are wrong
7D0-01-03 is number of lighting zones
7D0-02-02 is for power flow/climate bar
only possible in configuration I have found is in SCCM.
724-03-01 xxx*-xxxx--
it is type of right button panel on the steering wheel
!!!BE AWARE!!! I played with it and I locked SCCM for 8h with complete aku drained at the end...
m3iaz
Michal
Poland
Today I found VIN for new Raptor (25,5) and downloaded full AsBuilt data to compare with mine (24,5)
In codding there were no difference at all (even 1 Button Setup - same as my)
Differences I found was in part numbers of Buttons
Code:
2025.5
724
<F110>DSN1WT-3F944-AB</F110>
<F111>N1WT-14F078-MA</F111>
<F113>N1WT-3F944-ME</F113>
<F188>N1WT-14C579-AD</F188>
<F18C>109351032129</F18C>
2024.5
724
<F110>DS-N1WT-3F944-AB</F110>
<F113>N1WT-3F944-MD</F113>
<F188>N1WT-14C579-AC</F188>
<F18C>120041182203</F18C>
N1WT-3F944-ME - left
N1WT-14C579-AD - right
Right I understand (different icons) but also left is different (firmware?? hardware??)
APIM has some differences but I think it is just a firmware
Code:
2025.5
7D0
<F10A>MU5T-14G680-AA</F10A>
<F110>DSPU5T-14G670-GC</F110>
<F111>NU5T-14G681-LC</F111>
<F113>RU5T-14G670-TTN</F113>
<F124>MU5T-14G677-ADA</F124>
<F16B>MU5T-14J003-AF</F16B>
<F188>PU5T-14G676-GC</F188>
2024.5
7D0
<F110>DSPU5T-14G670-DA</F110>
<F111>MU5T-14G681-LG</F111>
<F113>SU5T-14G670-BGH</F113>
<F188>PU5T-14G676-DA</F188>
