2nd issue with 24 STX 4x4.
CHOPPY76
2024 Ranger STX 4x4
Millwright
Took my new Ranger back to the dealer to get the alignment set properly, it wasn't off horribly bad, but enough to notice. Was fixed with no issue. Now the fog lamps are not functioning properly. When making a left, or right turn the corresponding fog lamp will illuminate until the steering wheel is centered again. Not only that, but the drivers side fog lamp seems to have a mind of its own, and turns 'on' randomly when I've not activated the switch. Minor annoyances for sure, I'm sure the foglight issue will be repaired, but seems Quality Control needs to tighten up a bit @ Michigan Assembly.
Wayfaring Ranger
STL
This is a feature called Cornering lights. When your car detects you turning, it illuminates that side to give you better visibility. It's been a ford feature for probably a decade by now.
https://www.fordservicecontent.com/...a&div=f&vFilteringEnabled=False&buildtype=web
https://www.f150gen14.com/forum/threads/fog-lights-when-cornering-turning.14292/
CHOPPY76
2024 Ranger STX 4x4
Millwright
This new to me. Maybe I'm just noticing it now. Thank you.
