ANY INDEPENDENT DYNO TESTS DONE ON COLD AIR INTAKES FOR RR 3.0?
calelvis
joseph
Austin
2022 ford bronco/ 2025 ranger raptor
HAS anyone seen or done some dyno tests on the major brands of cold air intakes to see if they actually do produce any horsepower gains..
ie: K& N Advertises a 27 hp gain plus some torque... etc.. most others manufactures state hp and torque gains..??
looking to upgrade factory air box/filter if worth the dollars. some are a visual upgrade for sure, but would like to gain both power and appearance :). thanks!
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
I would say there's no gain, or if there is it's within margin of error or external factors. There might be an improvement with back to back runs, but even then I would be surprised if it's anything meaningful
The stock air intake is sort of already a cold air intake, the only drawback is the t-piece tubing that splits the air to both turbos - most aftermarket CAI have dedicated pipes or separate pod filters.
I know Fabulous Fabrications over here did pre and post dyno runs with their CAI - from memory there was only a few kw gain, not enough to not be margin of error or external environmental factors. The Fabulous Fab CAI is decent too - separate pod filters, aluminum design and fully sealed box. For the price you do it for the looks, or if you can have a custom ECU tune to take advantage of any extra airflow the CAI gives
Long story short - if you want power, you need a tune. An aftermarket CAI will support the tune. It's a support mod in my opinion. No point doing it without a tune (unless you like the look)
If you want some added sound, throw on a vent to atmosphere BOV - they're cheap and easy to install
calelvis
joseph
Austin
THANKS FOR THE INFO.. I DO HAVE THE FP TUNE, JUST WANT TO MAXIMIZE IT'S BENEFITS:)
stuartmunto
Stuart
Yeah even still, Ford Performance would have setup and tested the tune with the stock air box. Not sure if it will make much of a difference either way?
calelvis
joseph
Austin
maybe sound and looks is part of decision making:)
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
I tested S&B, picked up solid power up top. This was E50, but a good idea of what difference the intake made
Ford Ranger ANY INDEPENDENT DYNO TESTS DONE ON COLD AIR INTAKES FOR RR 3.0? E30_500whp vs stock intake_bigger diff up to
Carbon6G
Longwood, FL
I just installed the K&N CAI and I already had the FP tune on my 2.3. While I don't have any dyno charts to backup anything, there's a difference but I don't think it is what K&N advertises. It's definitely louder. K&N advertises some lower rpm gains but I think it's more throttle response than anything. There is probably more power up top and closer to WOT - similar to a Rousch CAI I had on a 2022. I do find the transmission is a little confused in normal and will not sit in the right gear but when in sport, it goes away. Maybe some lag now? The idle has smoothed out some.
Not super impressed with K&N with the materials and set up. The intake tube is right up against the charge pipe even though it is as far against the turbo inlet as it can go, and am concerned it might wear. Contacted K&N and no response yet.
calelvis
joseph
Austin
great info.. thanks gents!!
Mooncat747
Rick
southeast asia
2023 Ranger Raptor 3.0
Yep. I'm happy with the stock setup and aftermarket AF only. Sometimes I run a stainless one which actually makes a difference not only in power, but sound, and boost. Flows way more than any K&N, BMC can throw at it.
Ford Ranger ANY INDEPENDENT DYNO TESTS DONE ON COLD AIR INTAKES FOR RR 3.0? 20250623_143956
Ford Ranger ANY INDEPENDENT DYNO TESTS DONE ON COLD AIR INTAKES FOR RR 3.0? 20250623_144153
AMGRAPTOR
FL
2024 Raptor Ranger
Wow that’s a pretty good gain? Have you tested this with just a 93oct tune?
calelvis
joseph
Austin
thanks for the update,, wow, you're pulling lot of hp!! do you think this much tune is detrimental to the longevity of the engine life for the 3.0?? I have the pro cal tune on my 25 RR and I am a little underwhelmed with it.. running 91 octane.. my 22 2 dr. bronco has the pro cal tune on the 2.7 and I swear, it seems as fast as my RR with same ford perf. tune...appreciate your thoughts..!
Goosetuned
Gold Sponsor
Winfield
AZ, NM, TX
Professional Tuner
91oct I have. I saw a 15hp increase in power. It will be very very similar on 93
Lutrev
Alberta
Iconic silver ranger raptor
Who makes this one ?
