Anyone install Leer HF650M hard tonneau cover? If so thoughts???
Awirez
SC
Where the instructions specify. With the fasteners provided, in the front die down point.
derfeznoj
50 miles west of the middle of nowhere
Ranger
For folks with the factory spray in liner where are you attaching the brackets for the safety tethers?
There are two, threaded bolt holes on the inside of the bed just below the front hold-down bracket attachment point. However, with a spray in liner, the threads get clogged with excess spray. I used an 8mm tap to clean out the threads, then the included 8mm bolt threaded in just fine.
MikeVB
Georgia
2024 Ford F-150 work truck. Personal trucks: 2025 Ford Ranger XLT, 2002 F-150
Finally got my truck yesterday. Installed mine today. Great fit. Easy install.
Is it extending over the tailgate cap at all? It looks like it ends almost where the tailgate cap starts? Any leak issues so far?
How do they address the large gap at the front edge of the bed next to the rear window?
danmoochie
dan
florida
retired Sales manager
It does hang over the tailgate. Enough to stop water. At the front they provide a large foam piece that sticks onto the bed and blocks any water coming in. So far it's been perfect and I'm in Florida. We get rain lol
Flak
US
25 Ranger Raptor
Mine has been a bit leaky. It seems to be getting under the (too) small tonneau rubber gasket on the sides where it barely drapes over the metal rails. It might be getting in the back slightly as well because it seems like it doesn't compress quite enough. That one might be solvable by very slightly adjusting the rails, if I'm inclined to fix that. I am probably going to trim out the gasket/rails with a small amount of additional gasketing once it gets warm out and settles. Will have to see once I can test it with a hose and put a camera inside.
Most of the water doesn't get in, but slow leaks in heavy rain (or pressure washing like at the car wash) do happen. To that end, it's slightly better than my previous tonneau (Truxedo X15), but I think it can still be improved.
danmoochie
dan
florida
Don't forget, there is no such thing as 100% waterproof. I have owned several and this cover is by far the best, and without the annoying tubes!
Dre' Dawg
Andre'
Magnolia, Texas
2013 Shelby GT500; 2025 Oxford White RR & 2025 Shelter Green RR
It is by far the best cover I've ever had. The fit and flush mount is great. I put 1/4 on the rear seal to help with the tailgate cover and sealed the accessory caps on the bed rails with black silicon. This helps with water leaks but as someone posted you will never get 100% water proof.
3M Heavy Duty Double Sided Tape,15.6FT Length, 1/4 Inch Width for Indoor Outdoor, LED Strip Lights, Automotive Trim & Home Office Décor, Waterproof & Industrial Grade, Made with of 3M VHB Tape
Flak
US
25 Ranger Raptor
Sounds just like what someone without crippling OCD and perfectionism would say
danmoochie
dan
florida
wrong, I am a freak about stuff like this, and that is why after several attempts I found this cover to be the best. Go look at most my other posts and threads, they scream OCD.
mhorvath1218
North Jersey
‘24 Ranger Raptor
Hey did you ever sort out the leakage? Just installed this cover and am having leak issues - Just made a post about it
Ron Quixote
America
Several
I had difficulty with the HF6540M instructions in the box that didn't match the parts/hardware for the '25 Ranger so got some tips from danmoochie and LEER sent over some additional instructions and images in the pdf.
Thanks for this. I Installed mine on Sunday and that phantom 4th clamp has been driving me nuts. I was just about to email Leer about it.
Leer, if you're reading this, please update your dang instructions that you ship with the cover! :LOL:
Flak
US
25 Ranger Raptor
Mostly yes. However, the biggest problem is the thin foam underneath where the cover sits on the rails. It's fine but doesn't handle pressure from the side (e.g. car wash).
mhorvath1218
North Jersey
‘24 Ranger Raptor
That seems to be my leak source as well. Any tips on improving the situation? Mine leaked a ton all the way around in just regular rain
danmoochie
dan
florida
very odd, I installed my almost a year ago without any water issues, even in a car wash? Maybe they made a change on the latest version?
