ARB on board compressor mounting locations
Sauce
Northeast
2025 Ranger XLT FX4
I'd like to install an on board ARB compressor on my non raptor ranger with (ideally) an aux switch and hose quick connect on the bed panel. Seems like the three common mounting points are (1) under bonnet, (2) behind rear seat and (3) behind the bed panel. Trying to get input on pros and cons of each location for those who have done it. Below are some of my thoughts, but I could be wrong. Where did you install yours and why?
Under bonnet - simpler to connect power, but requires a long run to the bed panel for the switch and hose. Don't need to run anything through the firewall (at least I don't think so). Would much prefer to relocate the switch and quick connect rather than have them under the hood.
Behind rear seat - have to run wires through the firewall. Takes up some behind seat storage. Wouldn't bother running the hose or switch to the bed if it were in this location.
Behind bed panel - Close to the bed panel for switch and quick connect attachment, but far from power. How have others run power to this location (assume you run it under the truck, but this seems pretty exposed)? do I need to run a filter relocation for this location?
Seems like the ARB harness is overly complicated for this install (includes wires for lockers). Is there a simpler wiring harness, did you make your own, or just modify the ARB harness?
bossy
Jerome
Bellevue, WA
Some company just showed a custom plate for Ranger..
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
I’ve used a mounting bracket from PirateCampCo - not sure if they ship to the US, but it was super simple to install under the bed:
https://piratecampco.com.au/product...-under-tub-mount?_pos=27&_fid=5437a5089&_ss=c
This made routing the air hose to the bed’s electrical panel very easy, only needed a 500mm hose to go from the compressor to the back of the bed panel.
As for power, if you have aux switches the wiring is super easy - there’s the AUX switch #4 wiring (which is designed to be used for compressor power control) already routed the rear - it’s located near the trailer hitch wiring loom. This is very easy to hook up to the ARB compressor power control plug on the compressor. As for power, all you need to do is run two power cables from the battery to the compressor (the rest of the wiring that comes with the compressor can be discarded). I made my own wiring and just spliced in the fuses that came with the ARB compressor (spice in close to the battery so the fuses are in the engine bay).
Routing the wiring from battery to the compressor is also very easy as there is a wiring loom that runs along the chassis rail, I just followed that and zipped tied the power cables to the chassis rail. There’s plenty of earth connections on the chassis rail near the rear of the truck so earth is a short run from to compressor to earth. There’s also access from the front wheel guard into the engine bay so getting the power from battery to the chassis rail is also easy - just follow pre-existing wiring looms near the battery
I wrapped the power cables in spiral wrap, with heat shrink and electrical tape at the ends to hold it all together. There’s also a spare positive terminal you can use on the battery. Just need a nut and washer
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
I don't have a Raptor, so no Aux switches. But the switch shouldn't be too hard, and it sounds like running power from the battery wasn't too bad either. Did you have to relocate the intake filter? Not concerned with water getting that high, but that location could be pretty exposed to dust and other elements.
Pretty sure this mount also works in that position, just a slightly different configuration (supports the bolts from the other side of the bed wall).
https://ausmotion.com/product/arb-compressor-mount-ranger-ra/
stuartmunto
Stuart
Sorry - miss read your post. I thought you had AUX switches. Just a FYI, AUX switches are available on non-Raptor Rangers, you just need the tech pack or something. Well worth it as the pre-wiring simplifies everything
That mount you posted will work, it’s just more complicated as you need to drill through the drop in bed liner (spray in bed-liner I think has the holes pre-drilled). Access is very hard to get to the compressor also.
Not concerned with water with the under tub mount as I don’t do too many deep water crossing, but relocating the air intakes is quite simple given how easily accessed the compressor is
If you need to mount a switch into the cab, it’s also not too hard as there’s grommets on the firewall that allow wiring to enter the cab from the engine bay
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Pretty sure there isn't a package other than Raptor that offers Aux switches in the US. Probably different in Oz though.
Looks like all of the onboard mounts only work for the ARB dual. I was only planning to mount a single, so I'll either have to upgrade to the dual or fabricate an adapter. Just another complication to add to the puzzle.
Steffan
Steffan
Darfield, New-Zealand
2024 Ford Ranger Tremor, Bi-Turbo 2 Litre
lucky for us in NZ and Auzzie some of the other types come with Aux switchs, my Tremor has them and Im looking at wiring in my compressor as well in the back deck
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
I'd like to do an under the hood one but I don't think there's a mounting option out there yet for a RR
DZRT_80
Los Angeles
2025 Ranger XLT 4x4 - Previously for 23 years: 1996 Land Cruiser
Retired Architect
I'm curious how much dirt and debris gets up in that spot. Seems like rocks would still get kicked up, bounce around, and land on top of the compressor along with a lot of dirt.
Also, where does the wiring harness plug in (instructions go to wrong link) and does it provide power too?
Roverhound
Walter
Augusta Springs, VA
Mechanic
I haven't check for debris on the compressor but it is pretty well protected. I opted for the remote air intake that mounts behind the tail light.
The ARB harness is used and you plug the SDHQ harness into it. I used switch 3 to supply control power. The SDHQ harness runs up to the battery.
nate.co
Nate
Lafayette, Colorado, USA
2024 Ranger Raptor, Polestar 2
I have the SDHQ setup, havn't had any problems -- just got back from 1,500 miles to/from Moab and about 350 miles off road. No issues so-far.
The pirate camp one looks like it would not work with any of the aftermarket air intakes. At least the S&B I use definitely fills back to under the the washer fluid fill neck.
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
SOLA Motorsports
FYI, I'm working on a VIAIR compressor plus air tank mount right now that would be able to go on either the driver or passenger rear fender location. Our first production sample should be here late next week. It integrates mounts for air manifolds, relays, etc.
We will be selling under the SOLA Motorsports name. The website should hopefully be up soon! If anyone is local to the Baton Rouge area, we could really use access to a non-Raptor to verify fitment
Roverhound
Walter
Augusta Springs, VA
Mechanic
Viair was my first option, I even have the compressor but the just wasn't a very good mounting solution for me.
I'm interested to see what you've come up with.
And if anyone needs a compressor, hit me up.
https://viaircorp.com/products/ada-constant
