MAV
Arkansas
Can anyone verify the operation of the hood vents on the Raptor? It appears there are no cutouts in the underhood insulation, so I'm assuming these are just for appearance and non-functional.
SCFast
Washington
'24 RRaptor, '22 Ford Bronco, '18 Raptor Prior
Ford says they are functional on both the hood and fender
MAV
MAV
Arkansas
I hope so. My wife's Explorer ST with this same engine package gets HOT under the hood. No vents anywhere though.
MAV
MAV
Arkansas
That's the hood scoop. I'm asking about the hood vents - the plastic pieces in the back part of the hood on either side.
Soperfect
Kristi
2024 Ranger Raptor, 2023 Bronco Badlands
Business owner
Manual says they are functional, but I need someone to explain to me how they are functional. I don’t see how they can extract, no openings in hood insulation where the extractors are located ? ?
I
Ford Ranger Are Hood Vents Functional Ranger Raptor IMG_2047
Ford Ranger Are Hood Vents Functional Ranger Raptor IMG_2048
HyperM3
Lawrenceville, NJ
Yes they are functional
Coming back to this. From sitting behind my new RR for the past couple weeks, I dont see any openings in the vents over the hood. Is there something that needs to be removed or cut out?
MAV
MAV
Arkansas
I looked at a Raptor in a showroom a few days ago. The small holes in the rear of the hood provide the "functional" areas of the vents from the underside. Seems like there should be a much larger hole there, but then I'm also not sure how much air the vents themselves can actually move.
Ag3ntC00p3r
Product Manager
Functional seems dubious at best. The sound deadening mat blocks the hood vents but they will still expel heat via convection.
I'm planning on removing mine to paint sometime this week. Here is a video that shows how to remove them and what's under them.
Madtel4
Lee
20 Ranger XLT-FX4, 20 Explorer ST, 21 Mach HP
I don't see any holes in the vent the part he never turned over in the video. I think it only has a small water drain and no meaningful amount of hot air can escape.
Lee
MAV
MAV
Arkansas
I was just eyeballing mine yesterday thinking about how to cut a hole under each of the vents to make them more functional. This truck produces an insane amount of heat from under the hood, so much so that I usually open my hood to let it cool after driving.
