AWE Exhaust installed
Deepsea619
California
Tacoma
US Navy
Just got my AWE exhaust installed on my Ranger Raptor and so far I absolutely love it. I wish I knew some things prior that I found out after but I am absolutely in love with it. I have a AWE exhaust in my Bronco Raptor and I thought that was amazing but I think this one even sounds better well done AWE this should be a hit.
I added some pictures. I am pointed at the clamp. They installed it and it drove me nuts because it was just aluminum clamp and for some reason my eye was drawn just to the clamp so I painted mine so now you can see what it looks like painted but the sound is phenomenal. Maybe it’s all in my head, but I swear it’s a little more responsive a little more peppy, but I love it. Good job. I love it. I recommend it to everybody..
Ford Ranger AWE Exhaust installed imag
Deepsea619
Deepsea619
California
Tacoma
US Navy
I have tried to make videos of sound and all of mine suck. I’m gonna try one more time for a cold start.
boraxman
Santa Clarita, Ca. USA
Nice, waiting on mine to get delivered.
Deepsea619
Deepsea619
California
Tacoma
US Navy
It’s going to take a couple days to get use to the 5” tail pipes but your going to love the sound. Oh! You might smell something that smells like bury plastics. It’s normal, it will take around 100-200 miles to burn it out. I flipped out then I callled AWE. 100% normal.
scuba mike
Southern Calif
Hvac Job Foreman
5 inch tail pipes ?? wow..
Kian
NYC
'26 RR Avalanche Grey
about a week in and i'm 100% used to the 5in tips. i think it matches the overall look of the truck and doesn't look out of place. and even so, at least these RR's have the power to back it up. i've already posted in another thread, but here's a couple sound clips: the first is a cold start.. sorry the rev's are so shy, truck wasn't warmed up so i didn't want to over-do it. S
Second video has some better revs, i'm not sure what mode it was in though becuase i have having some issues with the actuator valve pin. After getting it fixed for a week now and getting used to the tone, i think it was in Sport Mode.
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
So what is going on with the cold starts? Obviously when you first start the truck up it sounds really good even with the stock exhaust but after 30 or 40 seconds or so the sound cuts in half. Any idea what that is?
Kian
NYC
Tbh I’m not exactly sure… but perhaps just sits at a high idle to warm up the truck faster? My neighbors 5.0 mustang always does the same.. could be a ford thing.
my issue was related specifically to the supplier that provides the actuators for AWE. They forgot (or poorly installed) the pin, and the motor was spinning freely, not making contact with the dummy plate therefore my exhaust was stuck in a one of the exhaust modes.
Christian/AWE
Gold Sponsor
Christian
Horsham PA
Chevy 1500, NA Miata, Mk7 GTI, BMW X5 Msport
AWE Community Manager
Chiming in on this to be informative: Modern day vehicle cold start behavior (elevated idle) is an ECU strategy aimed principally at effectively warming the catalysts for efficient function.
Most vehicle manuals will have a section detailing the proper "departure procedure" and state whether or not the vehicle should be allowed a warm up period or be driven directly after startup.
Christian/AWE
Gold Sponsor
Christian
Horsham PA
Our system does not come with a preassembled actuator. Instead, the factory actuator is transferred and mated to the AWE valve simulator plate during installation.
The process for correctly installing the supplied retaining pin is detailed in our instructions (page 9, step 11) and must be followed carefully to ensure proper assembly. If the retaining pin is not installed as instructed, the valve may not function properly, which can result in a check engine light.
If anyone needs assistance with specific steps in the installation process, please reach out and our support team can assist you.
Kian
NYC
Support team helped got me sorted 🫡
it’s the best sounding exhaust for the RR, hands down. I got stopped by a passerby the other day and told me it sounded great. He didn’t know about raptors obviously because he asked if it was engine swapped 😂
Havasu RR
Craig
Lake Havasu, AZ.
Entrepreneur
I assumed one of the actuators was doing something. It sounds to me like the idol stays the same. It just gets very muffled. But thanks for the info. I've had one over your exhausts on order for weeks
Christian/AWE
Gold Sponsor
Christian
Horsham PA
Are you using the quiet start function (sometimes referred to as the good neighbor mode) when you start the truck? The RR does have an awesome feature where it can be scheduled to start in quiet mode, hence producing the muffled sound you are referencing.
All of our systems are made right here in Horsham, PA. You can check the status of your order through our website right here: Order Status Check
