Bed Tie Down Hook Bolts!
Red Rover
Selinsgrove, PA
I had one bolt strip out because I did not have a T40+ bit and could not find one locally. I replaced all the bolts with these found on E-bay. Replacing all with Fords earlier T40 versions would cost twice as much.
Ford Ranger Bed Tie Down Hook Bolts! Tie Down Hook Bolts
clarke
Tennessee
2025 Ford Ranger Raptor
My bed was OEM spray lined, so I cut around the head with a knife and pulled the liner off the bolt head with a pliers. It pulled all the liner out of the Torx Plus head on the bolt. I then used a Torx plug bit (I think a 45) with an 18" breaker bar. I went slowly and the came out fine.
adrouin64
Austin
Jay, ME
Marketing Manager
Heat... I ripped the bed liner (because ford is dumb and sprayed over everything) off the heads of the bolts, then heated each one with a zippo lighter torch for about 10 seconds each. Just make sure you have Torx PLUS bits and go slow. I did still break one off and had to drill it out but the rest came out fairly okay.
Raptor Family
Dallas, Texas
‘25 Ranger Raptor, ‘97 Jeep Cherokee, ‘24 Lexus NX450h+
I've had mine for 53 years. I bought it for the exact same purpose. Mine was a Honda S65.
You guys are old—I’ve only had mine for 47 years—for a Honda SL100.
Raptor Family
Dallas, Texas
Has anyone tried an inductive nut heater? Usually, you would put the circular element over/ around the nut, push the button for about 30 seconds, and presto— the nut is red hot and easy to remove. I was thinking maybe, if the heating element was placed over the Head of the bolt for a few seconds, it might soften the loctite. My truck has factory Bedliner and I really don’t want to scratch the crap out of it cutting off bolt heads or drilling out broken bolts—I don’t want to melt it with heat either. Aren’t our beds made out of aluminum? Maybe that is why Ford put on so much loctite—to stop the natural galvanic corrosion between steel bolts and the truck’s aluminum bed. Inductive bolt heater tool looks like this:
Ford Ranger Bed Tie Down Hook Bolts! IMG_2667
purdyd
california
it’s steel.
only the hood is aluminum
at Least on the body.
canuckranger
Alex
Colorado Springs
Military
I'm having the exact same issues with my 2024 trying to install a built right molle panel. What is the thread pattern for these 8x25mmx?
Thanks
Raptor Family
Dallas, Texas
Worth every penny lol
Ford Ranger Bed Tie Down Hook Bolts! IMG_9004
I agree. I wish I had one 40 years ago. They work great for removing the Tie-down bolts and any rusted or seized fastener.
