Charging Fault Causing Other Faults
Zoobz
Zubin
Australia
2023 Ranger Raptor
Construction
Hey all.
I have a 2022 Raptor. And have been getting The following faults. Had a Diag. Tech from Ford look into it. The Service Tech said they performed some firmware updates, but did not tell me what the issue was. I guess they were only hoping the updates would have fix a bug.
I'm wondering if it is a low voltage issue that is causing these faults ot occur. The errors always differ. But the worst part is the infotainment screen turns off several times on a trip. Has anyone else had these issues.
TIA
Ford Ranger Charging Fault Causing Other Faults 20241103_112916
Ford Ranger Charging Fault Causing Other Faults 20241109_084331
Ford Ranger Charging Fault Causing Other Faults 20241108_172828
Ford Ranger Charging Fault Causing Other Faults 20241109_100638
Ford Ranger Charging Fault Causing Other Faults 20241108_172841
Ford Ranger Charging Fault Causing Other Faults 20241108_172837
Ford Ranger Charging Fault Causing Other Faults 20241108_071011
Ford Ranger Charging Fault Causing Other Faults 20241109_100640
Ford Ranger Charging Fault Causing Other Faults 20241108_073241
Ford Ranger Charging Fault Causing Other Faults 20241108_073232
Ford Ranger Charging Fault Causing Other Faults 20240817_065258
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
What is the actual battery voltage reading while driving? You can see the battery voltage in the measurments page in the drivers display. Might be worth monitoring it while driving. Could be a faulty battery or alternator issue? Both of which can be confirmed by any service centre
Zoobz
Zoobz
Zubin
Australia
2023 Ranger Raptor
Construction
I test battery voltage with multimeter. It was sitting at about 12.7V with the car off.
stuartmunto
Stuart
There’s little to no load on the battery with the car off. You need to monitor the battery voltage when driving - that is also when you’re getting these errors. The battery is also taking on voltage with the engine running via the alternator. You’re not testing much by just reading the battery voltage with the car not in operation
chuck
Nick
Lawton
24 ranger xlt 4x4
chuck
Nick
Lawton
24 ranger xlt 4x4
I had this problem with my 2020 Ranger. Battery and alternator checked good. After several trips to the dealer the battery finally showed on the diagnostic as the problem. Replaced the battery and all the problems went away.
Zoobz
Zoobz
Zubin
Australia
2023 Ranger Raptor
Construction
I agree. I just wanted to check the state of the battery.
Hootbro
Delaware
2024 Ranger STX 4X4
I am betting there is a ton of below minimum threshold voltage code causing the cascading error messages. I would be looking at the battery and main grounds for it.
Deleted member 9086
Have the battery load test. This is the only why to determine it’s charging and recovery capacity. Voltage checking won’t determine the state of the battery. Always do the simplest thing first.
Personally, what you’re posting gives the impression of a few cells in the battery are dead or on their way.
Yes, this can happen with a new AGM battery.???
