Curt Hitch installed easy peasy
2024Fx4
2024 Ford ranger
My brand new ranger did not come with a tow hitch. Not the biggest of deal aftermarket tends to be a lot better and stronger anyway as it mounts directly to the frame. I went with the Curt Hitch I've used them on past vehicles very high quality. This was probably the easiest vehicle I've ever put a hitch on. I was done in probably 15 minutes. All you have to do is use to c clamps pinch both sides of the bumper brackets not my picture I took, this one off of etrailer.com loosen four bolts take them out put the hitch up get the bolts started tighten them down and then torqued them to spec with a torque wrench. All I'm towing is my double jet ski trailer and my utility trailer.
Ford Ranger Curt Hitch installed easy peasy 20251204_142514
Ford Ranger Curt Hitch installed easy peasy 20251204_142535
Ford Ranger Curt Hitch installed easy peasy 17648767413567224055737496504507
I got my son the same one, i think. He did say ot was easy to install.
He lives in another state so i didnt get to see
mrmike7189
MA
2024 ranger STX 4x4
I have owned a few SUV's over last 20 years and they all came with the hitch as standard equipment, yet I buy a new pickup truck and it didnt have a hitch? ....so I also bought the Curt hitch.
Compared to the money that ford wants for their hitch.....the Curt is a steal!
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
Texas Truck Channel did a hitch install on theirs. I think they used Curt as well. Seemed straightforward enough:
mjpjr45
Michael
2014 Mustang GT, 2024 Ranger XLT
Safety instructor
Installed same on mine. Easiest mod I have ever done and it fits great.
Pebeto29
Alberto
Monterrey, Mexico
Ranger Wildtrack 2025
la wildtrack de mexico es diferente? pues pedi el enganche curt 13607 y no pude instalarlo pues no coincidia, alquien a comprado el curt para wildtrack??
Sharpix
Tony
MX
Tinkerer Fixer
Compra un tiron marca HUSKY. Los hacen en guadalajara. Mercadolibre. Queda bien. Algo laborioso porque hay que remover la defensa. La agencia me regalĂł el tirĂłn, ellos lo pusieron.
Checa este post.
https://www.ranger6g.com/forum/threads/trailer-wiring.7326/post-314518
Ahi se ve incluso el conector de remolque, bajo la batea.
OJO se ocupa un modulo de remolque (Tow Relay module, TRM) para activar ese conector. Ahi en ese conector se conecta OTRO cable que tiene en un lado el 4 o 7 pines.
Se manda la camioneta y el modulo A QUE LO ACTIVEN con su scanner. es un desmadre.
del conector de 4 pines de remolque:
Explico. La wildtrak tiene un sistema muy raro para los cuartos y freno. La calavera USA EL MISMO CABLE en la calavera, para los cuartos y el freno. Solo varia el voltaje para cambiar la intensidad de la luz: 2.4 volts para cuartos, y al pisar el freno da 12 volts.
Ahi el problema es que Si conectaras tu remolque desde los cables de las calaveras, no funcionaria bien los cuartos en el remolque, prenderian muy bajito casi sin iluminar al recibir solo 2.4 volts.
Ya pase por esas y no funciona correctamente.
La otra: Los cables de las calaveras son muuuy delgados. Sugiero para este modo, cambiar TODAS LAS LUCES DEL REMOLQUE A LED. NO USES EMPALMES/GRAPAS. Solo quita el forro del cable con un encendedor y solda. No rompas ni un hilito del cable de cobre. Si lo haces, un dia se romperan y te quedas sin luces en las calaveras.
LO MAS FACIL PARA 4 PINES (y tu remolque cambiarle TODO A LED)
o Compra en Autozone HOPKINS CONVERTIDOR DE LUZ LED RefacciĂłn # 48895
o Deben remover las calaveras y de ahi se conectan algunos cables.
NO LE PONGAS GRAPAS O EMPALMES ELECTRICOS. Esos rompen los hilos de cobre y podrian incluso dejarte sinalguna luz de la calavera.
DEBES SOLDAR. No cortes cables. Quita el forro del cable con un encendedor y luego solda. Poner ThermoFit o tubo termoencojible, no cinta de aislar.
OJO: Esta es la forma menos complicada, y si tu remolque tiene pocas luces y todas son led, es aceptable hacerlo asi. Si traes un remolque de caballos que trae muchas luces, debes seguir la siguiente forma:
La forma muy dificil pero correcta. $$$$$$
Funciona para todo, muchas o pocas luces, incandescentes o no.
Mandala a la agencia. La wildtrak NO TRAE EL MODULO DE REMOLQUE DE FABRICA PARA ACTIVAR EL CABLEADO ORIGINAL. Se ocupa mandar tu wildtrak a agencia, que ellos instalen Y ACTIVEN EL MODULO, y completen con un arnes atras, debajo de la batea, con cable de 7 pines.
Se ocupa: TOW RELAY MODULE (TRM), un bracket para fijarlo (va detras de la tapa izquierda de plastico, a un lado de los pedales de freno. Se quita y ahi por atras va el modulo y el bracket para fijarlo.
Tambien se ocupa un arnes que se conecta atras bajo la batea.
Sugiero compres la pieza de Autozone y la conectes en las calaveras. NO EMPALMES. solda los cables. NO LOS CORTES. solo desforralos y solda. Cubrelos con Thermofit, no uses cinta de aislar. Recuerda, Remolque debe estar en Led.
Saludos. tony.
BB1959
Bobby
virginia
2025 Ranger XLT
Will this hitch and ball be OK for a 2025 XLT? Or should I get one with more drop? I will be ordering the Curt tow hitch to install.
https://a.co/d/0istpNjR
Thay will be fine. I have the same but i have two with a different ball size on each one. (I have one trailer with a smaller ball so thats why i have multiple)
KRC
Karl
2025 Ford Ranger XLT
Diesel Technician
Nice! I ended up doing the Curt hitch as well, except instead of c-clamps I just grabbed some big bolts with nuts and washers for that spot, worked just as well!
