Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
Yes, with the seat still installed. Would you be coming through St George on Friday? We typically head out on the trail on the weekends.
No, I am coming from Reno, so if anything I would have to come on Saturday night or Sunday. I will be at the Spring Mountain Motorsports complex all day Saturday.
AdventureLab
Brit
St George, UT
'24 RR
+ 1 for one like in the first post - need one yesterday, have everything else for my install.
OK. So what I am going to do is go ahead and release the one you see here in the first post. I have several messages of people wanting this exact version.
As I can get to it, I will build the version that will allow for the ARB compressor. That will take a little more time since we don't have a vehicle at our disposal for this change. That one will probably replace the current one when it releases, but if you're not looking to mount a compressor, it may not be a benefit either way.
I'm going to work on this tonight.
AdventureLab
Brit
St George, UT
'24 RR
Gotcha. Let's stay in touch about it. Normally, I don't want our crew working on the weekends. We put high value on family/trail time. That being said, my time is pretty much free for the company. 🤣 So, if it's where I am in town, I'll take you up on it!
AdventureLab
Brit
St George, UT
'24 RR
Oreo_Five8
California
2024 Ford Ranger Raptor (Azure Grey)
I believe so, but it definitely complicates the layout a little. I also think it would need to jog back out to get back to the to the bottom vertical flange. I don't think there's as much room behind the bottom of the part as there is in the middle. It's hard to say here as I don't have our Ranger disassembled right now. It still has the Rear Seat Delete and OEM sub in it.
I could probably make that bottom vertical section a little shorter and tuck it under the carpet a little, so I could move the mounting surface rearward some.
The problem with stuff like this is if I spend a lot of time on it, it would either have to be really expensive or we would need to know there is ample demand there to cover the R&D cost.
I would love to be able to make it and know there were enough people out there wanting them to justify the effort. We have a pile of products in the hopper that already have strong demand and, unfortunately, I only have so many hours in the day.
Just got mine in today but I'm using a Kicker powered sub and it's a bit big for the rack as it is. I took some pics and have some possible changes to allow it to fit. I also plan on removing the center seat belt so that plastic cover should go away allowing for a slightly wider mounting area.
Oreo_Five8
California
I would like to think you're right. Hopefully some of those people could chime in here and add some fuel to the fire. 😁
I bought one of your racks and it definitely won't fir the Kicker Powered Sub I have. My intention is to us the base rack as a starting point and a friend will modify it with a plate that will mount my sub and once we have a working model I'll post some pictures here. I have an 8 inch powered sub and a kicker key to mount as well as a power distribution block to make it a complete module. When I get to that point I'll provide all the gory details and a parts list as well as pics from all angles.
AdventureLab
Brit
St George, UT
'24 RR
Much appreciated, look forward to taking a look!
