Cutting out the plastic webbing at cold air inlet
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Was looking close at the area under the front cowl plastic cover(radiator support shield) that feeds intake air up to the air box and saw plastic webbing(baffling ?)crossing the flow path, I understand it's there for some structural support but was considering trimming it out to get a more open flow path, any thoughts on if it could help flow potentially by opening that rectangle up? Bottom of photo shows the diagonal webbing plastic strips
Ford Ranger Cutting out the plastic webbing at cold air inlet Screenshot_20260709-114437
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Its part of the upper rad support, and its to help keep larger crap getting to filter.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Well whatever structural support and filtering the fins might do would seem to be minimal, of course any detriment to flow would be as minimal or less as well. I may think about cleanly removing the fins and installing a coated wire screen in the rectangle surround/frame
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Is interesting that the closest grille cells to it at very top of grille are blocked off dummy cells
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I can see the silly aspect certainly but based on the thickness of web fins, the number and orientation of the webbing, along with examining the surrounding structure I can't see it weakening the piece as a whole, except if there was major blunt force at the forward face, but even then there would be damage either way
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Running a ported TB and IM so thought it couldn't hurt potentially, and maybe get some more spirited mechanical sounds outside the engine bay? Probably really just to do it though
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Here is a diagram of the part, Front Upper Radiator Shutter Assembly- certainly not an inexpensive piece of plastic
Ford Ranger Cutting out the plastic webbing at cold air inlet Screenshot_20260709-145526
Ford Ranger Cutting out the plastic webbing at cold air inlet Screenshot_20260709-145533
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
You won’t gain anything from doing this. The amount of increased air you’re talking is insignificant and also you’re running the stock airbox. Even with more air coming in the stock airbox can’t do anything with it.
also without a custom tune, more air won’t equal more power (even with an aftermarket CIA)
another also: you have two turbos. Your engine is getting enough forced induction from the turbos, it doesn’t need any extra air
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I did remove #3 as it was a seemingly useless support for a small portion of the cover and clipped in with a 2 loose plastic tabs.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Oh sorry I didn't mention that was simply a example/sample photo above, not my truck /setup
JimG
Jim
Scottsdale, AZ
2025 Ford Ranger Raptor
I hope the modification won’t affect your warranty if something were to happen. manufacturer's or ESP‘s are always looking for a reason to get out of a warranty. But to some owners it doesn’t matter. I hope whatever your trying to accomplish it works.
