RogueLobo
- First Name
- Ron
- Joined
- Jun 21, 2024
- Threads
- 2
- Messages
- 50
- Reaction score
- 30
- Location
- Pittsburgh PA
- Vehicle(s)
- 2024 Ranger Raptor
Thank you Hofstetm! Awesome write up explaining all the tricks to get the Diamondback installed properly. Thanks for sharing for all of us waiting get the cover...@garagesale @jorosz0309 I was able to install my Diamondback SE this weekend, and honestly, it went surprisingly well all around. I still don't have my bulkhead weatherstripping yet, but I'll install when I get it. A few things I found.
Next up, I'll be adding the DB inside light, tool bar and 4 more cleats. it's sleeting outside right now, otherwise I'd head outside and take some pictures. Garage pics will have to do for now.
- You absolutely need 2 people for this job. It made it incredibly easy. One person in the bed, one person on the outside for reasons I'll mention in a bit.
- Even though I took a picture of my rod guide brackets for DB (they requested it and are sending me new ones because these were short, allegedly) the ones already on the cover fit great. They are pretty close to the furthest "down position" but having someone apply pressure to the cover to make the gaskets compress and tighten the brackets makes an awesome seal all the way round and the job of installing the brackets a breeze. Note that none of the rod guide brackets bind their rods at all. Maybe it's because of number 3 below.
- Rods. These all shipped short. But, are adjustable length wise with an allen wrench (I'll attach a picture). That, and they can also be turned/pivoted so the bend is at the outer most part of the panels and not in the middle (which would interfere with taller items in the bed). This is where the second person came into play again. I had someone compress the panel gaskets even more while I laid on my back in the bed, pulled the guide rods out with the allen key loosened until I had a good inch past the lip of bed and rotated where the bend of the rod was closest to the top. I did this on each rod, tightened the allen keys and I was set. To close the panels I'll press down on the panels to compress the seal and close the latch thereafter. There's no binding or rubbing, and everything has smooth operation. That, and all 4 rods have more than enough left in adjustment - see pic. Maybe this is known already, but figured it would be helpful to someone.
- Pet-peeve: The front (or cab-most) panel has driver side spring loaded latch and a dumb safety catch. I hate it. I honestly contemplated removing it all, but thought it might void their warranty - and decided against it. Safety, I guess.
- I also installed the UpTop Overland bars. These things ROCK. Super stout and match really well. Lots of adjustability. Do yourself a favor though and mock everything up first before installing the brackets on the DB, then attach the bars to the brackets, THEN install the brackets to the DB. The bars remind me of large C channel, and it's tough to get your fingers inside the bars to secure everything. And let me tell you, there are ~24+ lock nuts you'll have to get inside the bar so you'll get frustrated quick. Ask me how I know. Again, going this route might be beneficial with 2 people.
