patc890
Patrick
Rockville, MD
It's strapped to the existing mirror. I'll get some pics of that
Hi I was reading your post and you said you have the the Wolfbox webcam strapped to the Raptor's mirror. I just bought a Wolfbox G900 Pro with a 12" mirror. When I strap it to the Raptors it doesn't cover the mirror. There is about an inch sticking out on the right side. Is this how yours is? Thanks
PNW_Raptor
PNW_Raptor
Jon
Washington
Are you sure you got the 12"? I got the 12" version and it covers the mirror completely and overlaps a good amount.
Make sure they didn't send you the 10" version by accident.
patc890
Patrick
Rockville, MD
I'll check it and get back. Thanks
patc890
Patrick
Rockville, MD
So I realize what the problem is. I bought the polarizing lens. Maybe you didn't. You can see in my photos that I did get the 12". The next photo shows it on my RR mirror with a little sticking out(which I still don't like) but the next photos show it with the CPL on the RR mirror sticks out more.
PNW_Raptor
PNW_Raptor
Jon
Washington
Interesting, and you aren't able to move it to the right anymore because it hits the camera? Maybe this is because of the G900 Model, I have the 840s...
patc890
Patrick
Rockville, MD
That's probably it. Have you thought about replacing the Ford mirror with the Wolfbox. I'm not sure about removing it, I don't know how the truck would react? Or how hard it is to do.
wlarsen76
Wells
Figured I'd put this in-depth post together about my experience installing a digital rearview mirror and the tips & tricks I learned a long the way.
I have a tonneau cover, so I cut out a small piece of my weatherseal foam under the lip of it to run my cable through cleanly.
If you have questions, please ask them here!
First, let me just thank you for posting such a detailed article. This is incredibly helpful.
I wonder if it might be possible to take a pic of where you fit the wire through before attaching it to your bar?
I also have a tonneau cover (Retrax) and Yakima Overhaul HD Bars where I plan to mount the camera. I just cannot figure out how to come back out of the bed and up the bar with the tonneau cover closed.
PNW_Raptor
PNW_Raptor
Jon
Washington
Sure thing. Since my Billiebars system raised up my tonneau rails by about 1/8" it was easy to have the wire under there, then I just ran it through the bar channel and used electrical tape to secure it. I'm sure you can use some zip ties and it would work just as well. Here are some pics
PNW_Raptor
PNW_Raptor
Jon
Washington
And for anyone wondering, here's what the camera looks like mounted with the tent on.
wlarsen76
Wells
Thanks! I'll see if I can do the same.
Alternatively, I thought about just laying it along the t-slot groove in the yakima overhaul hd.
This is my project for the day. :D
wlarsen76
Wells
When connecting up the hardwire kit, did anyone have any issues with the bullet connectors when trying to attach the 'add-a-tap' from amazon? I can't get it to go in all of the way.
PNW_Raptor
PNW_Raptor
Jon
Washington
Yes, I did write something about that. I had to shave it down. I did it with scissors, if you have a utility knife and a steady hand it will be easy enough.
wlarsen76
Wells
Ha! I ended up mangling it. I just contacted Wolfbox. I guess I'll see if they can help.
