Ditch lights, vibration driving me nuts.
bonjo2
Avery
virginia
2025 ranger
First time with ditch lights. They are vibrating like mad. I tried XL 4” and then some s2 and not much difference. The 4” perfect sitting still, but enough to cause seizures to light sensitive deer. 2
The eBay steel a little worse than the thick AAL, but both driving me nuts.
how do the Baja guys mount their xl80?
bonjo2
bonjo2
Avery
virginia
2025 ranger
2” are worthless.
Shrek The Raptor
George
atlanta
I don’t think I’ve seen a ranger either anything bigger than a ss3 or lp4 on our brackets.
SDHQ seems to have a solution with some rubber spacers to keep vibration down and they’re running the lp4s.
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
Just think about what your asking the bracket to do. It's a lever. I have the AAL (second set as the first was not level, this set is better but had to clearance them to the hood because they touched) with Nacho Supreme 80's. Do they vibrate a little? Yes. Do I care that much? Not really. If you find a completely still set let us all know!
bonjo2
bonjo2
Avery
virginia
2025 ranger
I added a bit of rubber that has adhesive on one side (5mm) under the hood, above the mount, and will try and find a rubber bumper thing for the topside. There is a clear open hole in the AAL mount on each side. I'll post photos if it works out. I'll probably cut a 1.5" circle out of some PPF/Propeller edge guard to place under the bumper.
The baja race truck runs xl80's and now that I've exp a 4" 80 watt light, I cannot go back. They pick up where the high beams fall off on the side. Pretty amazing. Lots of glowing eyes at night.
NM Mike
I’m using the rigid D pro series pods on the AAL mounts and have no vibration on my passenger side and a slight vibration on the driver’s side light. I just came back from a week of mud bogging during elk season, so the light mount may have loosened a bit, as it didn’t vibrate before the hunt. I think the A pillar mounts might be less prone to vibration than the hood mount style brackets, but that is speculation on my part.
Trimjb
Tennessee
2024 Ranger FX4
Go pics of the ditch lights y'all are using?
I moved to deer country Cumberland Plateau and could probably use them.
Shrek The Raptor
George
atlanta
AAL with antenna brackets on driver side with SS3’s. I had SS5’s up there for a week but couldn’t deal with the vibration.
Ford Ranger Ditch lights, vibration driving me nuts. IMG_4104
Ford Ranger Ditch lights, vibration driving me nuts. IMG_4105
Ford Ranger Ditch lights, vibration driving me nuts. IMG_4103
NM Mike
Rigid D pro series light on AAL mounts
Ford Ranger Ditch lights, vibration driving me nuts. IMG_3916
bonjo2
bonjo2
Avery
virginia
2025 ranger
These little threaded silicone rubber bumpermade a huge difference. A couple turns on bottom bolt using a flat 10mm wrench to snug against hood and hold in place while tightening the top nyloc bolt. Pretty solid.
So 3/16” (not 1/4” like I mentioned) rubber strip 1.5x2.5 between underside of hood and the bolted on bottom bracket.
I think a better design would have fixed bumpers under AND adjustable bumpers on top and/or 1/4” stainless bracket. Or, make perm mount and skip all this bolt-on stuff.
Ford Ranger Ditch lights, vibration driving me nuts. IMG_1224
Ford Ranger Ditch lights, vibration driving me nuts. IMG_1225
bonjo2
bonjo2
Avery
virginia
2025 ranger
I’ll post an installed photo once I find time to cut a couple little bits of ppf. Maybe next week.
