Dobinson Rear Coil Spring Lift - anyone install?
E40
Andy
ATL
24 Ranger Raptor NE
Has anyone installed Dobinson rear spring on their Ranger Raptor?? Im wondering how much lift it will give to my saggy Raptor. I have Retractable cover + RTT which are about 270lb combined with cross bars. Then there will be another 300-400lb of camping gears that i need to carry for overlanding trip.
I think this will be my perfect set up with 2” strut spacer lift from GOAT Offroad:
https://dobinsons.com/ford/ford-86/ford-86_rear/ford-86_rear_coil-spring/ford-86_rear_coil-spring_c19-523-detail
Btw, attached pic is an example of fully loaded set up (approx 500-600lb total payload)
Ford Ranger Dobinson Rear Coil Spring Lift - anyone install? IMG_9699
embedded rock
Earth
One truck, two motorcycles
What if you add spring rubbers for when you have all the gear?
E40
E40
Andy
ATL
24 Ranger Raptor NE
Ed​
sounds like a decent solution for onroad, but the rubber spacer will decrease suspension travel which i want to avoid.
Roverhound
Walter
Augusta Springs, VA
Mechanic
I just installed air bags on my Raptor. I have a set of 1192 Sumo Springs if you are interested.
They helped somewhat when I was towing.
I used them because I leveled the front and as a consequence, when towing my camper the back sags.
I looked into the Dobinsons but the springs will raise the bed, and give you a harsher ride if they are not weighted. This is directly from Dobinson themselves when I contacted them.
Ag3ntC00p3r
Product Manager
Were you given a suggested static weight to reduce the harshness? For those of running permanent/semi-permanent racks and RTTs that likely wouldn't be an issue.
Maybe my google-fu is off today but I can't seem to find anything regarding 1192 Sumo Springs. Do you have any details on what worked for you bags wise?
BrrRaptor
Raleigh Nc.
Which airbag setup did you go with?
Roverhound
Walter
Augusta Springs, VA
Mechanic
Truckin
24 Ranger
It would be nice if Eibach made these for raptor.
I ran these rear adjustable on my 4Runner and were great for adjusting when needed
Ford Ranger Dobinson Rear Coil Spring Lift - anyone install? IMG_6238
