Does anyone make an insert for the coin holder (or whatever the heck it is)?
artvarck
Art
CO
2025 XLT 4WD
Almost retired
I'd like to mount a Redarc rotary dial in the coin holder, but don't want to drill anything. I can't seem to find an insert or blank in the aftermarket for this; anyone ever come across one?
Ford Ranger Does anyone make an insert for the coin holder (or whatever the heck it is)? 1785185082313-pu
That's where the trailer brake controller mounts. Maybe use that part to make/design your mount?
artvarck
artvarck
Art
CO
2025 XLT 4WD
Almost retired
Yep, that I know. The ITC insert is molded for the manual override lever, and won't really work for this purpose.
Loudpa
Given time and skill one could 3D print something perhaps like this.
Ford Ranger Does anyone make an insert for the coin holder (or whatever the heck it is)? coinslot
artvarck
artvarck
Art
CO
2025 XLT 4WD
Almost retired
I like it.
I don't have a 3D printer, but am not averse to buying one. I used Kiri to take a 3D image of the coin holder, but am at a loss as to how to proceed. Installed Fusion, imported the image file, and sat there clueless. Hence my question about whether anyone has seen this in the aftermarket.
How did you create that model, especially scaled correctly to the opening?
Loudpa
I like it.
I am no pro at designing things but have made several 3D designs. It just takes me a long time at times due to trial and error getting parts to fit.
Anyway I use TinkerCAD which is geared toward the beginer.
Aj R
Aj
Fresno
24 Ford Ranger FX4, 22 Ford Edge, 2001 F150
Building Inspector
I did exactly what you are describing. I bought the instrument panel molding for the factory installed brake controller from Ford had it delivered to my local dealer. I purchased some black ABS on Amazon cut and dry fitted before JB welding in place. Then use the Tekonsha 90920 Prodigy iD smart phone trailer brake controller. Had to trim behind the trim panel just a bit to fit the brake controller inside the dash. Took me about 6 hours total, I allowed the JBWeld to cure for a couple days before drilling and installing in the dash. There is a bit of panel removing around the steering column to do but you can find some pretty good videos on YouTube that can guide you on how to remove them.
Ford Ranger Does anyone make an insert for the coin holder (or whatever the heck it is)? IMG_2738
Ford Ranger Does anyone make an insert for the coin holder (or whatever the heck it is)? IMG_2739
artvarck
artvarck
Art
CO
2025 XLT 4WD
Almost retired
Damn, that's awesome! Thanks @AJR - I'll do the same! If nothing else, 3D printing an insert for the ITC housing (rather than the ABS you used) will be easier than attempting to do the same with the coin holder (or again, whatever that thing is, since it serves no real purpose). Thanks for the part number too.
