Does XLT have stereo EQ?
fastlane
indiana
26 ranger xlt
26 Xlt here. There are treble, mid, and bass adjustments….on the screen, each is a “slider” icon which you can move with Your finger or with a “+“ or “-“.
there Are also settings for sound position reflected with a picture of the inerior…you move the arrows or drag the “dot” on the screen.
also a speed sensing volume adjustment.
and there is a setting for “all seats” or “driver”.
coming recently from a 21 f150 with the standard stereo (I was happy with), I just could not get this system to sound decent with any adjustment. I tried changing out the front tweeters and front door speakers….brightened it up a bit, but still not good.
after adding a powered compact sub that I took out of my previous truck and also changing the EQ settings in Forscan to flat, it’s much improved. There is more presence in the front. The only caveat is that doing that, the “all seats” and “driver” settings are now gone. They were trash anyway IMO.
there are a number of different EQs in Forscan. Default was #1. I went to #0 (off). Not sure what the other ones get you….did not experiment.
alrashid2
alrashid2
PA
coming from a 21 f150 with the standard stereo, I just could not get this system to sound decent with any adjustment. I tried changing out the front tweeters and front door speakers….brightened it up a bit, but still not good.
Thanks for this info! Were the FORScan settings in the easy mode, or in the more difficult AS BUILT settings? I'm not seeing any instructions in the crowdsourced FORScan excel
SLJ
The Finger Lakes
Righteous! How difficult was it? I used to swap speakers on early 2000s vehicles all the time but wasn't sure if modern vehicles were more difficult. As simple as popping the door panel off, unplug speakers, pop in new ones?
Bought them from Crutchfield. The come with the correct brackets and plug and play cables for the Ranger. Took me around ten minutes per door.
fastlane
indiana
26 ranger xlt
Was in the “as built”. On the spreadsheet in the ACM, it shows which number/bank to change.
normally I only change the easy stuff, but in this case, I was willing to give it a try.
alrashid2
alrashid2
PA
Oh that is awesome. I will definitely be buying some Kickers from Crutchfield then.
Thanks so much for giving me some confidence!
SLJ
The Finger Lakes
If I remember correctly you'll need a T20 bit for the door screws (four screws per door).
alrashid2
alrashid2
PA
Super easy! Right on, thanks man!
sdca7718
VA
‘26 RANGER RAPTOR ‘20 EXPLORER
Also good to have a plastic panel pry tool to help get the door handle panel and pop the panels after you get the screws out. Watch flaberdoopin YouTube or the many others on how to remove the door panels. Just don’t pry the cable release like he does, there is a simple tab that you push to release the cable. Everything else in his video is good knowledge for swapping speakers and installing sound deadening.
alrashid2
alrashid2
PA
Thanks for the tip
The video seems very in depth!
SLJ
The Finger Lakes
Crutchfield also supplies very good step by step PDF instructions with photos for the Ranger.
RonEee
Ron
Holland Michigan
2025 Ranger XLT
No? haha. Some base stereos only have like 2 clicks up or down for these adjustments, some have 10 or more.
Just trying to anticipate if there is much adjustment available or not.
I'm going to get Forscam and make my adjustments go to 25. It won't be any louder than 10, but it will go to 25 , 😂
Tri5Ford
SW Minnesota
2026 Ranger
Hey guys. I thought I read about someone on here needing FORScan in order to get the tuning settings on the stock stereo. Is that true?
Ordered a 2026 XLT so wasn't sure if maybe it just wasn't added to the base XL, or maybe I just heard wrong, or maybe the Lariat with the B&O sound system has a better EQ system? I just need the basic Treble, Mid, Bass adjustments.
Curious, thanks guys!
Could you possibly go to a/your dealer and look on a ranger?
Christopher
Christopher
2025 Ford Ranger XLT 2.7L engine
FYI, I currently have a 2025 XLT. The standard radio in it is sub-par... I had a third-party sound system installed and it sounds great! It is far superior to the Lariat premium 10 speaker sound system as well. I had a 2020 Ranger Lariat with that system. It doesn't matter how many clicks the EQ may have; it is not going to help with any fidelity what-so-ever...
alrashid2
alrashid2
PA
Thanks for the response! When you say sound system, do you mean a new stereo in place of the giant 12" screen? Or just speakers replaced?
I've got some Crutchfield Kickers bookmarked in case the speakers arent up to par with what I like!
alloyz250
So Cal
2026 Ranger XLT FX4
Curious, what kind of cash might a 3rd party system set a brother back?
