Electric handbrake, automatic ?
Raptortugal
Portugal
Ranger Raptor 6g
I've always been in the habit of putting the handbrake on my cars.
On the Raptor the handbrake is electric.
It disengages automatically, but is there a forscan mod so that it activates automatically when the ignition is turned off ?
I find it convenient that the gear lever automatically goes to P, but it's a shame that the whole procedure isn't 100% automatic.
Awirez
Most vehicles I've driven, a lot of rentals, the electric parking brake would normally be set to engage when put into Park. I would imagine the actuators pulls a little bit of power and would work best with the engine on. I don't have a truck yet, and I don't see anything in the owner's manual about the parking brake automatically engaging, except for vehicles with electronic shifter, which is only the Raptor now.
unixadm
Sacramento, CA
On my prior 2021 F150 Platinum, the parking brake would seemingly set if the truck was parked on a steep incline. My 2024 RR doesn't do this when parked on the same incline. It would be nice if it did.
This is what the manual says about Electric barking Brake:
Automatic Transmission Positions - Park (P) - Vehicles With: Electronic Shift
Ford Ranger Electric handbrake, automatic ? {filename}
WARNING: Shift into park (P) only when your vehicle is stationary.
In park (P) power is not transmitted to the driven wheels.
Note: A tone sounds if you attempt to exit your vehicle without the vehicle in park (P).
Note: Your vehicle may not shift out of park (P) if the 12 V battery has run out of charge.
Note: Your vehicle may not shift out of park (P) if a fuse is blown.
Note: Your vehicle may not shift out of park (P) unless the key or remote control is inside your vehicle.
Note: The electronic parking brake could apply when you power your vehicle on with the selector in park (P).
Note: The electronic parking brake could apply if you shift to park (P) without fully pressing the brake pedal.
Note: The electronic parking brake could apply if you shift to park (P) on a slope.
Note: Do not manually release the parking brake when the selector is in park (P). See Automatically Releasing the Electric Parking Brake.
Note: Your vehicle could shift into park (P) if you attempt to exit your vehicle without the vehicle in park (P). See How Does Automatic Return to Park (P) Work.
Note: A tone could sound when you select park (P).
Does it actually work that way? I don't know, I have never tried it.
