Justin_Glen
Justin
AUSTRALIA
MY24 Ranger Platinum
STOREMAN
Has anyone tried to turn the little number values for the displayed small gauges. Underneath the fuel gauge it shows DTE. I’d like to also see oil pressure, coolant temperature etc.?
i have seen it turned on but I don’t know what forscan function it is.
I'll look at my setting tonight.
I'll go over my settings tonight. Tyre psi and temperature are pretty cool too.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 20241017_161559
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
For the seatbelts, which one just gets rid of the need to press ok? I'm fine with an alert, but get tired of hitting that button.
Holy gods from the multiverse - please rid us of that stupid half-screen menu telling me seatbelts are on until I push OK. Dumbest thing Ford engineers could ever consider.
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
That' doable with XLT? That is epic and now I need FORscan...
you don't even have to manipulate the code, there are check box options in the module select alternate menu.
They show up like this:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_2581
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_2582
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet IMG_2584
shraptor
Australia
ranger raptor
I’m interested to know if you have got oil pressure to work. That’s the one I haven’t got going.
what vehicle do you have?
I don’t have the selected gear showing either on the bottom left side
joordan
Italy
ranger wildtrak 2023
the selected gear is a default feature, you need to press the side button on the stick
shraptor
Australia
ranger raptor
Interesting that’s not a default function on an Australian ranger raptor, hitting the side button on the shifter puts it into manual mode.
joordan
Italy
there are three buttons. one put you in manual mode, the others when in manual change gears. but if you stay in automatic, and press the +/- button that shows you the gear scale on the dashboard. there is actually another hidden feature with those buttons, which is limiting the gear shift by pressing - in D
Jalbano2
J
NYC
Maverick Lariat Lux
Can you please provide detailed forscan instructions?
SF Bay Area
Cool Dude
For 8" screen on XLT, has anyone found if there's a mode to always show the gauges, like transmission & boost?
3 line menu key on steering wheel > Offroad> Vehicle gauges. Toggle on off once selected by reverse pointer st wheel key.
DirtDerrick
Nathan
Atlanta
dirtderrick.com
People Person
There have been several threads about FORScan, but would like to consolidate into one place like was done for the 5G Ranger.
The below document will be updated as people give confirmation as to what works and what does not. I am hoping to find GUI changes as Asbuilt changes together if possible, like you will see on the Confirmed tab for the Chimes and Bambi mode
Web version: FORScan NA Ranger 6G
Actual Gsheet: FORScan NA Ranger 6G - Gsheet
The 3 most useful tabs:
  1. Features Confirmed - these are options that are proven to work on the Ranger
  2. Features TBD - these were collected from F150, Ranger5G, and Bronco and need to be confirmed
  3. FORScan GUI - this is a dump of all the options for all NON-ASBUILT module pages in FORScan while connected to a 6G Ranger
IF YOU CAN CONFIRM a configuration change works, if you could post to this thread with this information:
  • Feature name from the Feature Tab
  • What value you changed from -> to (asbuilt only, or GUI)
  • Ranger trim level tested on
  • Any side effects or gotchas when making the change
  • Any other details of what the feature actually does (in layman terms)
Please PM me if you would like to be an editor for this sheet or request access from within the Gsheet.
** NOTE ** The sheet may take some time for changes to get entered after there are posts with confirmations. So be patient please :)
Thank you ? for working on this.
