CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
there are three buttons. one put you in manual mode, the others when in manual change gears. but if you stay in automatic, and press the +/- button that shows you the gear scale on the dashboard. there is actually another hidden feature with those buttons, which is limiting the gear shift by pressing - in D
Ranger Raptor only has one button on the stick and that is for manual mode only. Instead of the other two buttons on the stick we have flappy paddles for gear changes.
joordan
Italy
ranger wildtrak 2023
ah that's right, so do not know if you have the same functions out of different button combinations
Border411
Shaun
Northern VA
2017 Ridgeline (trade in on a 2024 or 2025 Ranger)
Private Security (Retired Law Enforcement)
I tried to get rid of the seatbelt message using the "as built" and changing all the values to zeros. However, when I write it some values change back to the previous values. Any thoughts?
Justin_Glen
Justin
AUSTRALIA
MY24 Ranger Platinum
STOREMAN
I changed the location to Euro/UK and the seatbelt warning disappeared completely.​
Border411
Shaun
Northern VA
Where do I do that? I did change something to European (per the spreadsheet )and it got rid of the dinging.... But the message is still there.
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Hello, I’m Dan, and since July 2024, I’ve been driving a Ranger Wildtrak. While searching for Forscan enthusiasts, I couldn’t find anyone in Germany and came across your forum. Wow! Much respect. This is exactly the kind of spreadsheet I’ve been looking for, as well as people working on it! Keep up the great work.
A few days ago, I also set up an old MacBook with Windows via Bootcamp, got myself an adapter, and installed Forscan.
Here are the modifications I’ve made and documented so far:
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Bildschirmfoto 2024-11-30 um 19.25.08
Approach detection control function and walk away lock does not work ?
craigc
craigc
Craig
Allen, TX
Approach lighting works for me (North American Lariat). If you mean approach unlock, yeah, i don't think that works, but it does do the lighting.
Sequoia
Dan
Germany
Does not work here. Switched on all "Approach" things in the moduls. I mean the lightning.
sloon
Michal
Česká republika
Ford Ranger Raptor 3.0 V6, 2023
In ABS you will probably have a number like 760-03-01 F27C 562F, so rewrite 5 to D as shown in the table.
HyperM3
Lawrenceville, NJ
Yes, as long as you save it with the zeros and write, it should have saved. Even if the values populate back after the writing.
Sequoia
Dan
Germany
I was successfully able to activate Trail Turn Assist.
1) go to APIM and activate Trail Turn Assist
2) also in APIM (or in IPMA, not sure right now but it is clear to find): activate "off-road trail turn assist indication
3) ABS as build: go to 760-03-01. The second box is 5627. Replace the 56 with D6.
After writing it will show: D6A7 (that's correct).
Now you have a working and indicating Trail Turn Assist.
Border411
Shaun
Northern VA
See...I did all that and the box and the "ok" still show up, but the seat icons are gone. I'll have to try again I guess.
