moproblems
SW MI
Someone go try this on a 2024 Lariat.
Do it now.
734-01-04 may differ from raptor. If anyone has issues that will be where the issue lies. Just keep me updated and if need be I can do some checking if it doesn't work.
radial
Rich
Maryland
I've got good news for everyone, I have finally figured out anti-glare high beams for 6G USDM Ranger Raptors. Remember, all changes are at your own risk, however I just got out of the truck after testing this for a half an hour. It's the real deal.
Coding is as follows:
IPMA706-01-01xxxx, xxx9, xxxx
SCCM724-04-01xxx3, xxxx
IPC720-10-01xxxx, xxx2, xxxx
HCM734-01-02x2xx, xxxx, xxxx
HCM734-01-04xxA0, D1xx
APIM7D0-09-01x1xx, xxxx, xxxx
APIM7D0-09-03xx8x, xxxx, xxxx
Remember, do NOT replace any data with an "x", only the actual digits shown. Make backups of your vehicle as always.
This was done by comparing European and Australian asbuilt dumps to the asbuilt of my truck and I used the old F150 guide for direction.
Happy New Year everybody!
(please update the spreadsheet once you test it @craigc)
Wow, can't wait to try this out! Can you say a little more about the testing you did to verify activation of the anti-glare headlight functionality? I want to make sure I get this right.
moproblems
SW MI
Just drive around at night. Being behind somebody else or with traffic oncoming you will notice immediately.
I also figured out the anti-glare coding on the current generation M3-M4 before anybody else did. It works exactly the same, if not as precise as the laser headlamps on that model.
radial
Rich
Maryland
Thanks, okay, I'm going in. If not tomorrow, the next day for sure. Will report back.
craigc
craigc
Craig
Allen, TX
Hey fellas, thanks for all the great information here. I'm about to get started on this to enable rock crawling mode, adjust tires once installed, and number of turn signals. In reading through the spreadsheet, I don't see a way to disable the "keep your hands on the wheel" lane keeping nanny. Did I just miss that, or is it not able to be turned off in FORscan?
I enabled rock crawl, but i don't know much about what that mode is supposed to do. Pretty sure what I enabled is not enough though. I have not yet found any proper way to disable the nag, so it probably isn't possible.
craigc
craigc
Craig
Allen, TX
703-01-04 may differ from raptor. If anyone has issues that will be where the issue lies. Just keep me updated and if need be I can do some checking if it doesn't work.
the version of the spreadsheet that was used to create this one has no reference to 703-01-04, so we probably need to get an updated one. I have no idea who has access to that. Other than that, seems like a lot of different settings to tinker with. When updating the master sheet, I'm trying to find all the "non asbuilt" settings, so will take a while to figure all that out.
I don't think I'll be trying this out on my truck, so as any of you confirm, please help update the sheet - you can request write access.
moproblems
SW MI
The old F150 guide references it, it's a requirement for the coding to change the software mode in the HCM. Not noted on our spreadsheet however as I retrieved the info from a EU market truck. It is required as otherwise you will get a "High Beam Assist" failure and a few codes for incorrect module installed.
Most of these changes can be done via nonasbuilt changes, the only thing that is not is the changes in the HCM. It's just telling all of the modules GFHB is enabled and then just enabling it in the HCM.
If you gave me a dump of your HCM I can verify that line you were considering for the purposes of science, worst comes to worst I can get the correct data from a European truck. Easy stuff.
(EDIT) I realized it is not 703-01-04 it is 734-01-04. Correcting my original post now.
OccamsRanger
Might not be. I just used Forscan for the first time- enabled rock crawl (that shifts it into 4L and turns on the front camera to see obstacles better), changed the turn signal number, and a couple other small things.
Thanks again for all the info here, makes it doable for a noob.
HyperM3
Lawrenceville, NJ
Thanks for this, you rock! Can you explain what I will notice when this is working? Will one highbeam turn off while the other stays on? Will it swivel out of the way?
JustNick
Nick
BatonRouge
Shelter Green Ranger Raptor
Engineering Project Manager
Sequoia
Dan
Germany
Ranger Wildtrak 2023
Still searching for the "Wheel-Camera". I have the button now under camera views but it does not work. Even not working in 4L nor rock/crawl mode.
DIYPSCM
SF Bay area
2024 Ranger 2.7 Lariat
Today...
Rock crawl, approach lighting, tire temps.
Running out of things to change that I even care about.
MEB
Edip
Dubai
Ranger Raptor 2024
Is there any setting anyone knows about the lane keep assist. With both my hands on the steering wheel, it still constantly nags ' keep both hands on the steering wheel'
They already are you ..... 😡
I have to constantly move the steering wheel to stop it from nagging
Now I don't use lane keep assist but wish I could
OccamsRanger
I had the same question on a previous page, so far nobody knows. There are some options in forscan for lane keeping but not sure what they do .
Jalbano2
J
NYC
Maverick Lariat Lux
That is not something that can be manipulated in FORScan.
