not me but i will gladly read along in hopes of you getting helped
a77cj7
Sturgis, SD
98 Ranger
Guys, help. I was messing with forscan on '24 Ranger Wildtrack 2.0 bi turbo (euro model) and disabled ESP / TC button.
ESP works fine,disables itself when I go into 4 Low, butthe actual button is "dead". Anybody know what setting control this.
Just load your saved as builts to the modules you were modifying and try again. If you haven’t saved in awhile, you’ll have to redo any previous changes you’ve made.
I save my code for any module I plan to change before starting. Saves rework if errors occur.
Tunisian
Taghouri
Tunisia
2024 Ranger XL
Look at the IPC Advance track control or Advance track hard button control
HoppeRanger
2024 XLT Ranger 2.3
Theres a lot of information in this post.
I activated all the drive modes, and turned off the belt chime.
I would like to disable the start/stop but it seems you can only turn it completelyoff , rather than default it to off but leaving the option to turn it on should you want.
So my question is, can you make it default to disabled start/stop while leaving the option to turn it on yourself?
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
Does anyone know how to remove the top speed limiter. I did the police changes, and set it to 140, but still limited to 107.
a77cj7
Sturgis, SD
98 Ranger
I bought a hardware module for this. There are several available now if you search.
Border411
Shaun
Northern VA
2017 Ridgeline (trade in on a 2024 or 2025 Ranger)
Private Security (Retired Law Enforcement)
Does the rear seat have presence sensors for the seats AND the seat belt buckles or only on the buckles ?
Let me explain:
- for a few weeks after buying my Raptor, when a rear passenger sat down WITHOUT buckling his seat belt the display turned gray
- when he buckled it the display turned green
- and if he unbuckled it turned red
Now if the rear passenger sits down without buckling his seat belt it is as if there was no one there, however it is displayed in green if he buckled it and red if he unbuckled it.
It is as if the car only "sees" the rear passenger through the buckle and no longer through the presence.
I should point out that I did not yet have Forscan at the time.
How is it at your place ?
That is the same thing that is happening to me. My XLT (US) doesn't know there is a passenger unless they are "seen" through the buckle. If they unbuckle while moving, the icon shows red, dings for about a minute on and off, then stops dinging. The seatbelt screen will stay displayed.... But after a few minutes will disappear.
Raptortugal
Portugal
Ranger Raptor 6g
Ah, I thought I was dreaming, but actually no...
@Border411 Has the detection ever worked for you before ?
Yet under the seat I don't see any wires, only wires at the loops. How is the detection done ?
Any other cases on the detection of rear passengers?
Border411
Shaun
Northern VA
I had previously changed the code on like day 4 of ownership.... And that is the only way I remember passengers being detected. No idea regarding how the detection is done because I noticed the same thing... Although I really haven't looked for where the wires connect from to go to the seat.
Raptortugal
Portugal
Ranger Raptor 6g
So for you the detection worked at the beginning before having modified the code ? Mine stopped by itself, I did not have Forscan yet (maybe an OTA).
For me the fact of pressing OK to make the message disappear does not bother me, it disappears by itself after 45 seconds.
But I would like the detection of rear passengers to work again before the seat belt is fastened.
Border411
Shaun
Northern VA
Yes... It originally worked as intended
Raptortugal
Portugal
Ranger Raptor 6g
Ok, did you note the coding before modifications so that I can compare with mine ?
I tested the top speed limiter, finally. Still at 107 so if theres a zombie apocalypse, i might be in trouble
So the line that says disable auto start/stop nag isnt just the screen turn off? It turns off auto start?
Yup, just took the a off thr screen. Still shuts off at lights, oh well.
But, i did acrivate the compass on the xl 8" cluster, snd it works while driving and matches what direction my phone says. I also checked all the splash screens settings and only the raptor one works.
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 20250404_180558
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet Messenger_creation_6F534F90-ECD1-4699-828D-32FEBAD111F7
