craigc
craigc
Craig
Allen, TX
Guys, who is responsible for updating the spreadsheet? I decided to take a look at it again today and realized it's quite outdated. There are more confirmed features that are not updated there yet.
happy to give access to update the spreadsheet. What do you say is outdated? Be sure to look at the "confirmed" tab. the other tab still has remnants of the F150 info and/or things that haven't been confirmed to work yet. As HyperV noted as well, what region is something not confirmed? I originally created the sheet to be the North America version, but over time it's also included non NA versions as well (it's just hard to keep track of all the reginal differences, so it is possible something in NA doesn't work for others).
All in all, the spreadsheet is really just a guideline - anything and everything on there is to be attempted at your own risk.
Breakthrough
Ontario, Canada
2025 Ford Ranger XLT
Replacing the 2 with the 3 gets rid of the "full view not available"
Re: Removes black box on reverse camera that says "full view not available"
This didn't seem to work on my 2025 Ranger XLT (NA, APIM 7D0-02-02 xxx3 xxxx xx--), has anyone managed to get this working on this MY/trim? I can't imagine it would be trim specific, but might be for model years... I can try again to see if maybe I messed up resetting the APIM, but I thought the adapter did that (saw the screen reboot), and also did a few key cycles.
Edit: Seems to be working now, I must not have reset APIM correctly.
craigc
craigc
Craig
Allen, TX
This was one of the first things I did on my 24 Lariat. wonder if something changed in 25...
MuleMarine
2024 Ranger XLT Sport
Quick question on the Trail Turn Assist, under:
ABS760-03-01xxxx*x--* -> Bit 4 (add 8 to enable)
in the * position I have a "7". How would I go about adding "8" to that? Would it carry over into the second space at make "15"? Thanks.
craigc
craigc
Craig
Allen, TX
Yes. 7+8=F. So put f there.
Border411
Shaun
Northern VA
2017 Ridgeline (trade in on a 2024 or 2025 Ranger)
Private Security (Retired Law Enforcement)
Still not good enough IMO. Should be able to note that it is a result of owner configuration or something. I prefer driving my truck in Sport mode. I'm not flooring it all the time, but it's def more responsive and feels like it shifts better. I get that these are all first world problems, but would be nice to do a Ronco and 'set it and forget it'.
I'm with you. If I remember correctly, my 2017 Ridgeline would restart in Eco mode if I had pressed the button prior to shutdown. I could be wrong.... But I think that is how it was.
craigc
craigc
Craig
Allen, TX
Awwwww...I was way off..lol. Thank you!
Yeah sorry, I'm a nerdy electrical engineer, so hexadecimal, binary, etc are all basic to me - so not I'm always clear :)
KiwiRaptor
New Zealand
MY22 Ford Ranger Raptor (Next Gen)
Hi All, I have a couple of questions I hope someone might be able to help me with! First of all I attempted to enable the DRL Control in the APIM which did work to the point the menu appeared in the infotainment screen, the strange part is it didn't do anything at all and the DRL's went from being constantly on to completely off regardless of light switch position or toggle switch in the menu. Due to this I disabled the DRL Control function and the DRL's started working again but only when the light switch is in 'Auto'. if I turn it to 'O' they go off now?! I actually don't mind this but I'm confused what made this happen as they were permanently defaulted to 'ON' previously....... any ideas? I also enable the 'Auto Lock Control in the APIM as suggested in one of the feeds and the option appears in the infotainment menu options but its greyed out and does nothing.... Any ideas on this also? Appreciate any help offered!
@Dunko, I can't help you with the DRL situation, but the Auto Lock Control is easily solved. You've got half the solution already. You also need to enable Auto Lock Vehicle in the non-as-built BdyCM module. It's actually shown in the updated version of the Forscan spreadsheet on page 1 of this thread.
Breakthrough
Ontario, Canada
Thanks for confirming, I just re-did this today and it seems to be working now. I probably didn't do a full power cycle for the APIM on the first time.
No, just the gauge works on my truck, i dont think i did the numerical one but i will look tomorrow. My son and i played with a bunch of stuff so he could learn to use forscan so we turned lots of stuff on and off
53vodich
Australia
Everest 2024
Im in Aus where we have the ford everest. Most things have been exact same on Forscan however I am unable to enable Welcome Lighting features. Changing the parameters didnt work. I even copied the whole code incld checksum from a Aus Ranger but no luck.
any Aus in here that have been able to enable this on their everest?
