renato23
Renato
Brazil
Ranger Black 2.0
NC
In the spreadsheet, under disabling all seatbelt warnings and chimes in IPC (zero all values), it states use at own risk, unsure if airbags are disabled. Has it been confirmed that it does/does not disable airbags yet (preferably in USA)?
i did all the changes but haven't tested out the airbags deploying. i can say yes, it turns off all the crap that pops up though so i no longer have all that extra junk showing up on the screen at start up.
Hande
Hannu
Estonia
Business Owner
"Pro Trailer Backup Assist"
Has someone activated this by Forscan? RR 2024 seems to have basic tow/haul package, but how about Pro?
Jeffola
Southwest Florida
Business Development
Hande
Hannu
Estonia
Business Owner
Wouldn’t you need the control knob to steer?
I understand that you steer with drive mode selctor 🤔 As far as I understand, only missing hardware is on/off button inside the drive mode selector, but it can be turned on from IPC or Sync as well.
How_Dooo
Samuel
quebec
Ranger lariat 2025
"Trail Control"
Did someone with a non-FX4 ranger 2024/2025 did (or could) try to ENABLE the APIM : Off-road Menu
And try to access to the offroad menu with this option (in yellow) :
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765144466591-h1
It would give access to the Offroad menu without the physical button & the option to unluck Trail Control (with unlocking another option in Forscan)
I want to buy a used 2025 Ranger Lariat but it doesnt have the FX4 package, so i would be grateful if someone can try.
Thanks
chasc
Illinois
2024 Ranger
I can’t say whether this is a blocker, but every vehicle I’ve seen with the Pro towing option from the factory has an extra light to the left of the tailgate handle. So there may be other hardware differences too.
Hande
Hannu
Estonia
Business Owner
Thats probably how it is. Thank you! :)
Tunisian
Taghouri
Tunisia
2024 Ranger XL
Thanks
Waiting for an answer
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765205011211-xo
I enabled everything that a 4x4 has except the rrapter setting because i dont have the exhaust system and the cameras. I dont know what off road menu is though so i dont know what to look for.
And my truck os a 2x4 stx and i was able to turn everything on and it all does something when i shift through the trans settings. The rear locker engages and the trans shifts like its got low gears in certain settings, like if i had a tcase and selcted low range
How_Dooo
Samuel
quebec
Ranger lariat 2025
How_Dooo
Samuel
quebec
Ranger lariat 2025
Took those screenshots from a video of a guy that has a FX4 ranger :
1-
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765242339657-vd
2-
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765242381183-74
3-
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765242413573-tf
so does enabling the APIM « Offroad menu » on a non-FX4 truck allows this?
Tunisian
Taghouri
Tunisia
2024 Ranger XL
1-
2-
3-
Ooh ! I thought you were asking about the offroad driving modes selection without a physical button! I already have this menu !
But with no driving modes selector button I can’t activate sport or crawling mode
Ford Ranger FORScan NA Ranger 6th Gen (2024+) Crowdsourced Spreadsheet 1765269077801-sj
