Found a nice center console organizer tray, red edged silicone pads for Raptor
FloppyKnockers
Fort Worth, TX
2024 Ranger Lariat
Found another that has two trays, upper and lower;
https://www.amazon.com/gp/product/B0DBVBZM3G/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
Going to try these out and see.???
What in the name of center console tray amazingness is that?! Now I will have to be on the lookout for a center console extension collar - no more than 8 - 12 inches high. Then I will try to find/fabricate a 5-layer console tray. I will be the envy of the nation wide console community.
FL
Not sure if you got cheated or rewarded. The stock tray is an insult to center console trays. The Amazon ones are probably the best upgrade yet.
I ordered it from Amazon and by the way, I just got ripped off by RealTruck so beware!
TNMike
Tennessee
The Lone Ranger
Oregon
2024 Lariat
I have this tray set and it fits perfectly. I keep a charging cord plugged in so it can be a bit bothersome getting below the lower tray. They're sturdy enough so I'll be notching out the corners at the access holes so that I can remove either or both trays more easily.
How much room below the bottom tray - or does the bottom tray sit flat on the bottom of the console bin ?
TNMike
Tennessee
Lone Ranger, the distance between the bottom of the lower tray and the floor of the well is right at 3½". Keep in mind the usable space in the lower tray is minimal...think ink pens, etc.
The Lone Ranger
Oregon
2024 Lariat
So ordered one two days ago from Amazon and it arrived today - really pleased - everything seems to fit correctly and maximizes the space in the console. Even came with rubber pads you can take out for cleaning if necessary. For $25 this is a great deal.
Odb6909
T
This is a great addition to the truck. The only thing I didn't like was the hole that's provided so you can still use the 12v socket. I'm working on prototypes to print a plug for it. This is what I've got so far. Once I get the shape and little ledges dialed, I can work on making it useful. Little bin for small parts, put some holes in it for golf tees, etc.
How shallow can you make it? Wanted to get something to put over center console safe. Thank you!
Johnny 5
John C
Mold maker
Here's a double tray that my wife and I have for our Ranger Raptors. Once you learn how to use holes, used to run your charger cable through, to pull them out and put them back in, these are great!
https://a.co/d/3swkdcV
bigb
Tucson
2025 Ranger 2.7
Bringing this topic back to the top, I'm looking at that Muslogy set which is also offered in a set with 2 trays and a hidden box that fits up into the console lid.
I know the lower tray is not exactly very useful and will probably just use the upper tray, but it is cheaper to buy the set than to buy the single tray and hidden box separately.
But I am wondering how deep the top tray is, if it is as deep as the single tray purchased separately. The separate top tray is about 2" deep, is this the case with the top tray of the 2 tray set? They don't give the measurements.
Another thought is the hidden box may limit how deep I can pile stuff into the top tray but that's probably a good thing.
Heck even using just the lower tray without the top tray would be better than what I have now which is no tray.
Here's the 3 piece set: https://www.amazon.com/Muslogy-Organizer-Compatible-Accessories-Two-Layer/dp/B0DGQHRCHK/ref=sr_1_4?adgrpid=186750404819&dib=eyJ2IjoiMSJ9.tD_3W9vCihwWIlbnjQcOvM8KzvLjuKlgo18yqU_HO6ldDNvcKaUaSQ-zZkLEaee2FZkUu78BQOS2bQafGwalCFCoR-Ed_3M34nkjPevhHK35fH6884QYF0ifVjg0naek_YLYw9dR2Wb6Ht-DmH2tpxU0nLxwW-EBkOu5S9d-3ZVqqhWFVt-D8GoXEEVtnRI35RX6escJMxT6D9mfWDFAXxPiM4fkzNEBcKQFquHHFMI.Zb_6PCMUc-YVnVqIs-ZdeX1XLA8zhxjM0Ly3JnNd7Nw&dib_tag=se&hvadid=779548446915&hvdev=c&hvexpln=0&hvlocphy=9030244&hvnetw=g&hvocijid=2308852119745611671--&hvqmt=e&hvrand=2308852119745611671&hvtargid=kwd-2426171217526&hydadcr=10446_13816005_2425169&keywords=2025+ford+ranger+console+tray&mcid=8f9b7a8868c636c28b4d012ce7fcad12&qid=1762822729&sr=8-4&th=1
