Front Fox Shocks' springs are off-centered
E40
Andy
ATL
24 Ranger Raptor NE
While I was changing my engine oil, I noticed that front coilovers' springs are not centric to the shock. Also, springs seem like they have slightly bowed inward to the engine side. Is this normal??
Ford Ranger Front Fox Shocks' springs are off-centered KakaoTalk_20260309_120416463_01
thats kind of odd. i wonder if its just the dust cover.
i have seen springs that are curved in or out on lifted jeeps but not on a truck. i suppose it could happen just as easily though
hsun85
CA
Ranger Raptor, 4Runner
Mine are the same. no idea if it is normal.
Ford Ranger Front Fox Shocks' springs are off-centered IMG_6333
Ford Ranger Front Fox Shocks' springs are off-centered IMG_6331
E40
E40
Andy
ATL
24 Ranger Raptor NE
@superj Dust covers seem to be straight and are in-line with the shock shaft.
@hsun85 that makes it 2 of us. It seems like "bowing" effect is greater on yours. Any ride quality issue?
I don't hear any noise and don't feel any binding tho...
hsun85
CA
Ride quality seems ok. But something in the front suspension is making a squeaky noise when the truck is cold, and it goes away after 10-15 mins of driving. I'm suspecting the front shocks.
E40
E40
Andy
ATL
24 Ranger Raptor NE
Gotcha. No noise for me, but I feel like my fronts are sagging without any extra weight on front axle. I measured 20.8" on the driver side and 21" on the passenger side which are almost 1.5" lower than factory height (per GOAT offroad).
hsun85
CA
I went back to look at TFL's launch video. The launch vehicle also appeared to look like ours.
Ford Ranger Front Fox Shocks' springs are off-centered Screen Shot 2026-03-12 at 10.53.15 AM
MillerTime
RJ
2024 Ranger
Mine too. Had to have the dust boots replaced. They tried to realign the spring and it still rubs. I’m currently following up to maybe get a whole new set of
Ford Ranger Front Fox Shocks' springs are off-centered IMG_8936
Ford Ranger Front Fox Shocks' springs are off-centered IMG_8935
smprfiguy
San Diego
25 desert sand RR
photographer
Just posted because looks like im having the same issue, what was the end result of your situation?
OxygenMask
Phil
Eugene, Oregon
There's nothing wrong .
They're coil springs.
Ever play with a slinky?....
NM Mike
Coil springs will shift positions. If you are grabbing some air, driving at high speed or doing any of the fun things that a 4x4 truck is capable of then the more likely it is that the coil springs will move. You ca recenter the springs, and its probably a good idea to do so if you are getting any rubbing on the boot or shock body.
rocsteady
New Jersey
Federal LEO
This is the only pic I had handy of mine. Not sure if it shows what you guys are seeing or not.
Ford Ranger Front Fox Shocks' springs are off-centered 1779798305055-v
