popupstands
- Thread starter
- #1
Vehicle: 2024 Ranger Wildtrak Double Cab, UK RHD, built Feb 2024, 2.0 Bi-Turbo.
I'm planning a sealed enclosure for a 12" sub (Audison AV 12 D2 II — needs about 21 litres net, 88 mm mounting depth plus 30 mm rear clearance) and I'm looking at the front passenger footwell.
Before I start cutting MDF/PLY I want to know if anyone here has genuinely built and lived with a box down there, because two things are bothering me:
1. Airbag zones. My build data lists CN9AB0 "NAS knee bolsters – passenger" and CP8AB0 "inflatable knee bolsters – driver", so on paper my passenger side is a static bolster rather than an inflatable one. Can anyone confirm that's how UK/EU Wildtraks are actually built? The BEMM for P703 shows a passenger knee-airbag envelope of roughly 540 x 400 x 170 mm and a front-airbag envelope of roughly 630 x 550 x 600 mm reach, and a normal upright box parks itself right in the middle of both.
2. Whether an angled box is a real solution. My thinking is a wedge sitting on the floor — roughly 420–450 mm wide, 450–520 mm along the floor, 180–220 mm tall at the rear, 100–140 mm at the front, driver laid back at 25–30 degrees firing up and rearward. That keeps the vertical profile low and out of the deployment cone, in theory. In practice I don't know if 21 litres net will physically fit under the glovebox once you account for the heater ducting, the wiring loom and the seat rail.
Questions:
- Has anyone built a footwell or under-glovebox enclosure in a T9 (2023 onwards) Ranger? Photos and dimensions would be gold.
- Did you make a clearance buck/template first, and how much usable depth did you actually find at the floor and under the glovebox?
- Did an installer or MOT tester ever flag it as an airbag obstruction?
- Anyone got measurements off the passenger knee bolster area, or a photo with the lower dash trim removed?
Questions:
