Has anyone added Lariat side Mirrors to an XLT?
geoman
Rochester, Illinois
2024 Ford Ranger Lariat, FX4
I’m considering adding a set of Lariat side mirrors to my XLT. The XLT does not come with puddle lights and turn signals built into the mirrors. I picked up a pair of lightly used 2024 Lariat mirrors in a salvage yard that I want to change out with my XLT mirrors.
I previously had a 2021 F150 Hybrid that I added towing mirrors to. I purchased a set of towing mirrors with the power extend switch and then purchased the driver and passenger side wire harnesses for the doors that would plug into the mirrors and then plug directly int the central wire harnesses going to the dash. I didn’t want to figure out the different “pinning” wire procedure that some guys are really good at. I’m not one of those. The truck was a Lariat and already had most of the functions except for the power extend feature and the side mirrors cameras (didn’t have 360 on the truck)
So what I’m wondering is could you put the new Lariat mirrors on the XLT, buy new driver and passenger door wire harness set ups that will support the mirrors and plug them into the primary wire harnesses for that runs to the dash or would there be more wiring that would need to be done in the dash to support the turn signals and puddle lights? Could this be a fordscan flash that could be done at the dealer to make them function after all was installed? Let me know what you think! Thx.
Stu x 4
Stu
Don't know the tech behind the mod for switching out mirrors, but I do like the zone lighting (puddle lights), camera and especially the folding mirrors when I park in the two-car tight garage with my Lariat. I clipped the mirrors plenty of times on my GMC Yukon parking at night especially. That switch is on the door panel; might be another mod needed.
I did see some running boards (if wanted) that had some lighting features but would not help with your desire for turn signals on the mirrors.
Best of luck!
Did you pull the mirrors off the donor Lariat? How different are the plugs?
Could you not have pulled the harness off the donor? Or would that have been too much
hassle?
Reddog99
So. Cal.
2024 XLT Ranger FX4 2.7
The wiring is going to be the big stumbling block. The lights and cameras in the mirrors and the folding motors need to be paired with the door switches and computer controls. Your truck needs the "Technology Package" to get the stuff you want. I'm going to guess that you're S.O.L. as far as retro-fitting goes.
geoman
Rochester, Illinois
hassle?
The wire harnesses from the donor vehicle the mirrors came from were not available. Too bad as it would have saved some bucks. I have not pulled the door panels off yet to get to the final pin connection that the harness plus into going into the truck body.
My truck has the Technology package….folding mirrors, heated seats, full Max towing package with oem dash mounted brake control, large touch screen etc. I have a shop locally that is willing to run the necessary wires from the door/body connection to the turn signals and puddle light setup if needed. Since my truck has the folding mirrors function but not the lights, cameras and turn signals, I was thinking a wire harness swap may do it? It was a really easy swap out on the F150. Was hoping this would be as easy!? Thx all for your thoughts!!!
Highspeedplay
Keep us updated I was looking in to this as well.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
how did you make out after? looking to do the same to mine. but i got to get the non 360 cam ones.
salesman is trying to get me heated mirrors or atleast the insides as both of us didnt realize the xlt blis mirrors are non heated. lol
funny my 2012 eacape xlt has heated and my 2025 ranger xlt does not.
I do miss the convex/spotter/corner mirrors that where built into my escape mirrors, that stupid bright orange light is after jump scaring me when I glance at the mirror and blinded by the light lol
Intercontinental_Ranger
Cambridge
2025 Ford Ranger XLT FX4
Crisis Cowboy
Did you have any luck with this? Don’t care about puddle light, but would love to retrofit a heater if it’s feasible
ShadowDragon24
2025 Ranger XLT Fx4
in the process. got the glass ordered, and my cousin in the parts dept was able to to find the mirror side pins for the plug. then once the mirrors show up, gunna test fit pins for the heater connection.
so once I got everything, Ill be doing a post. pop off the door trim in the corner and look at the plug and see if you got this wire circled, means your truck is pre wired.
this is the wiring diagram for the driver side. the green and violet wire is the heated glass power. and it uses the ground thats already there. my xlt is pre wired for the spot lights, turn signals. and heat. as they are options for xlt.
Ford Ranger Has anyone added Lariat side Mirrors to an XLT? Screenshot_20260116_095813_Messages
Ford Ranger Has anyone added Lariat side Mirrors to an XLT? Screenshot_20260108_214747_Samsung Internet
Ford Ranger Has anyone added Lariat side Mirrors to an XLT? Screenshot_20260108_215008_Samsung Internet
Ford Ranger Has anyone added Lariat side Mirrors to an XLT? Screenshot_20250515_133641_Samsung Internet
Cambridge
Crisis Cowboy
I appreciate you - that post alone is a couple hours of research saved.
