Help with wiring?
KRC
Karl
2025 Ford Ranger XLT
Diesel Technician
So currently I have a few added accessories that have I essentially wired into the marker lights using the F150LEDs harness on each side. I have enabled the marker lights to come on with the DRLs through FORscan so everything comes on when the DRLs come on.
However there are a couple things that I would like to just wire to an accessory circuit, I guess? I want them to come on as soon as the truck is powered, regardless of if the DRLs or marker lights are on.
Does anyone have experience with these trucks and figured out the best place to wire stuff like that in at? I was thinking just a fusetap on the ACC fuse, but it seems that fuse is in the interior fusebox, and there does not seem to a corresponding one in the fuse box under the hood.
F150LEDs
Thomas
2024 Ford Ranger & 2019 Ford Ranger
CMCO
Hey @KRC Thank you for the support and glad to hear you are enjoying the plug and play adapters! How was installation?
As suggested a switch panel may be your best bet! We serve ours below as well that does have memory recall when powered!
LED AUX Switch Panel
bgn
Seattle
2022 Maverick Lariat FX4
There's a rubber grommet through the firewall on the driver's side.
KRC
KRC
Karl
Diesel Technician
Embarrassingly the second one was a lot easier to install than the first one! I didn't realize when installing the first one that the marker light literally just comes out, I'm not sure why I didn't realize that, maybe it seemed too easy? But the first time I took off the fender liner and ran it all that way haha.
Those harnesses are amazing though and definitely not a purchase I will ever regret!
I will look into your switch panel, a switch panel has been on my list anyway!
