HomeLink Issues
  • Thread starter Deleted member 13915
  • Start date
  • Watchers 7
I have a brand new 2025 Ranger Lariat that I picked up about a week ago. Over the years I have owned several vehicles with HomeLink and have never had a issue with it operating my garage doors. However this unit in my Ranger has been nothing but a problem. My other cars all operate the doors fine. It is inconsistent to say the least. Sometimes it works, most of the time it doesn't. I have erased the codes several time and reprogrammed it to no avail. I do have the stick-on key pad on my driver's door that was installed by the dealer. Is is possible that it is interfering with the frequencies? In other Fords that I have owned HomeLink worked flawlessly.
Any thoughts? Anyone else have this issue?
Sparky62
So Cal
I had similar issues, wound up extending the antenna wire on my opener with a piece of #14 THHN coper wire, seems to pick up the signal from my much better from further down the street now.
GLW
Missouri
On my 24 RR the only way I could get the connection (learn) the first time was to use the garage opener fob. It would not learn with the outside keypad or the purple button on the opener. Super pain but been fine ever since I was able to get finally get it connected. Not sure if that has anything with your situation or not.
good luck.
reds10
Dan
Arkansas
I just picked up a '25 raptor last week and my homelink stinks as well. It works half the time. My '24 expedition works 90% of the time. :/
pkvir
Paul
North Texas
2025 R Raptor. No issues here.
My opener stopped working last week. The first thing I blamed was Homelink.
The root cause was a failed capacitor on the power supply board in the door opener.
$0.90 fix. I can activate the opener from 6 houses down the road now.
Well knock on wood. Mine works perfectly.
and I get fairly decent range,
I hope you get this figured out,
2wheelfish
OC Cal
Mine works most of the time on my 25 Raptor, but range sucks and occasionally it seems to have a hard time opening the door while right in front of it. My other cars homelink seems better. Probably need to make my antenna on my opener a little better to pick up the weaker signal.
Of course, after I write a post about HomeLink it starts working. I extended the antenna wire to see if that helps.
JimG
Jim
Scottsdale, AZ
2025 Ford Ranger Raptor
No problems with mine. I have 3 doors and they all work flawlessly. How old are your door openers. You could always find a buddy or family member and program their opener. Might tell if it’s the truck or the opener.
sometimes it seems to work faster when I'm a house down the street rather than right out in front of the door
I don't think it is substantially any different than any other homelink I've had or my stand alone openers clipped to the visor
Medic 6
Rob
Greencastle, PA
Mine works with no issues other than it was a PITA to program.
Dre' Dawg
Andre'
Magnolia, Texas
I had an old opener and burnt it up trying to program the opener. Your problem might be the garage door opener as the new one allows me to open the door 25 yards away, anyway much further than the old opener.
I agree it is a pain in the ass programing it as you do need the remote key fob opener to begin the programing other wise it will not work... remember knock three times.. I mean push the home link button three times to get it to program!!
