How do I put a regular split ring on the key fob?
cho frank
Utah
Am I missing something obvious? I’ve pulled the emergency key out and it’s still a closed loop. Putting a split ring on it the classic way seems like it will permanently deform the ring and/or scratch the fob because the loop is so bulky.
Ford Ranger How do I put a regular split ring on the key fob? IMG_3293
It will get scraped when you put it on. But, it will also get scraped in your pocket over time. The split ring will just be the first scrape
surfstar
CA
2025 Lariat 2.3 FX4
Mine came with thin / single pass ring.
Work fine
Ford Ranger How do I put a regular split ring on the key fob? PXL_20260902_035538952.MACRO_FOCUS~2
I just noticed the silver part is actually metal so it shouldn't get scraped.
Ford Ranger How do I put a regular split ring on the key fob? 17883219214655439977087893500732
OxygenMask
Phil
Eugene, Oregon
Every time the dealer service advisor hands me my fob back it has a ring and tag on it....
I don't add these stupid huge fobs to my key ring. I usually put it in a lower pocket and fuggidaboudit....
cho frank
Utah
Thank you for confirming that not using the fob ring eliminates the fob-ring problem.
OxygenMask
Phil
Eugene, Oregon
My point I guess is there is no problem. People put rings on these all time. My wife put rings on all hers. Wasn't a problem.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Get a higher quality ring and it won't reform. Use a flat head screwdriver sideways to keep it open while you roll it around to help minimize scratching.
My "daily carry" key has nothing else on it other than a silicone cover. No rings, no keychains. I don't carry house keys because all my doors have key-code locks.
My secondary key does have a "remove before flight" style keychain so it doesn't get lost as easy
OxygenMask
Phil
Eugene, Oregon
Those wire things were included with my fob covers. Never used them though.
Ford Ranger How do I put a regular split ring on the key fob? 20260902_124005
natkill
OK
2026 Ranger Lariat 2.7L FX4, Marsh Gray
I have the same setup as your lower key, case and all. Those cable rings are so handy, and with the case I don't worry about my fob getting scratched or dropping it and the fob breaking apart (something that happened to my old fob a couple times).
OxygenMask
Phil
Eugene, Oregon
I don't use the wire, I just put it on for that photo.
I learned about the vinyl covers on here.
I didn't install the back half of the clear cover. Too bulky. Plus I didn't get them to protect the fob, I got them to help prevent negligent discharge..err..accidently locking/unlocking/panic alarm. Happened easily with fob in pocket. Hasn't happened since installing the covers.
natkill
OK
Gotcha. Maybe I'm old school but I still carry my fob with a house key and I have a cash can where I keep $70 in case I'm ever in a pinch. However, I just realized OP might like the keyring I do use for the non-fob things. It's the Exotac FREEKey system. Super handy, I've had it for probably close to 10 years now. It's possible to get the fob on one of the small rings, but since I put the case on my fob, I just haven't fought with it to see if it would still fit. I just use the cable ring.
The main Exotac ring is nifty because it has a spot where you squeeze it and it lifts the opening of the ring so you can easily get things on/off.
https://a.co/d/03X37Zke
WV-Mtnyr
NoVa
Grand Marquis
I use these...detachable quickly.
Ford Ranger How do I put a regular split ring on the key fob? 1000030222
