- Joined
- Feb 27, 2025
- Threads
- 35
- Messages
- 1,011
- Reaction score
- 1,497
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
Good case for synthetic oils and paper air filters changed regularly. It's almost always a maintenance issue and GDI engines just require that extra rigorous maintenance. I'm still up in the air about the real necessity of induction services though.
I wonder how many GDI engines have issues because people fail to install the air filter correctly, use sub-standard filters, don't change their filters regularly or use K&N / AFE Dry types which let in far more particulates than paper filters.
I stated this before, but had an 07 Focus ST back in college I got used for cheap (paid cash). Nothing special, just had a Duratec 2.3L NA engine that was port injected. I was young and dumb, so I bought a K&N fender well intake as the factory "filter for life" was clogged and needed replaced.
That was at 104k miles. By 140k miles the intake runner valves (changed the intake trackt length for low or high rpm) wore out as Ford just used plastic bushings, so theyd wear and rattle / not seat right (well-known issue).
Replaced the intake manifold, lo and below that Port Injected intake was filthy! It was full of grit and oil built up all over, including the intake valves. Port injection didn't eliminate gumming up, but I'm sure it would have been worse had it been DI.
So don't assume port or dual injection will save you from buildup, as it does occur on PI / dual injection engines as well, just not as quickly.
