KRC
Karl
2025 Ford Ranger XLT
Diesel Technician
Ford Ranger Installed the Raptor style grille! 81799-55d0b12f85a7a93458d28d48d2c88327
Ford Ranger Installed the Raptor style grille! 81797-2e1255465a6018ac0f6afe36c34c608c
Put it in last night while I was at work (diesel mechanic) and had some downtime.
I am really liking the look, I had thought about painting the FORD letters the same gloss black that is on a lot of the trim pieces on the truck, but I kind of like the contrast it has now.
Just waiting on the wiring harness from F150LEDs to connect the lights.
Aircraft examiner
Nice!! Looks great
jmt8706
2025 Ranger Lariat
Makes the front end look more beefy. I like it.
Bruce
Bruce
Minnesota
So was it 3 pieces????
And how badly did you damage the original grille?
And as a smart ass comment --- do you still have all your fingers?
Reactions: KRC
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
why buy a sepperate harness? ford provides 3 blunt cut wires under the bcm/trm behind the driver side kick panel, a ignition trigger, a marker light trigger, and a high beam trigger. run a wire out throught the use them to power htommet like they show, and use that the lights. they are powering my grill lights off the marker, and my Diode Dynamics D-Switch uses all 3. the ignition to turn on and off with the truck(besides being able to hit a bitton on keypad and use while truck is off) the high beam on 1 of the programable trigger wires to automatically turn on my light bar with my high beams. and the marker trigger to turn on night mode on the d switch(once I get my dd light bars, will tell the d-switch to turn on the back lighting on the bars/cubes) aswell and like I said turns on my grill lights, and the backlighting of my fog lights.
looks good tho
Ford Ranger Installed the Raptor style grille! Screenshot_20250621_073140_Adobe Acrobat
Ford Ranger Installed the Raptor style grille! 20250822_150423
Ford Ranger Installed the Raptor style grille! 20250822_150431
Ford Ranger Installed the Raptor style grille! 20250830_230434
Ford Ranger Installed the Raptor style grille! 20250802_180908
Ford Ranger Installed the Raptor style grille! 20250802_180922
Ford Ranger Installed the Raptor style grille! 20250810_131122
Ford Ranger Installed the Raptor style grille! Screenshot_20250922_091559_Adobe Acrobat
ryanO
Ryan
2025 RangerXLT
Sales
Ha! Ole Gullo Ford. I bought mine at Planet Ford, Spring. You in the Conroe/Tomball area?
Where did you get this grill? Looks great!
Reactions: KRC
dpAtlanta
Just North of Atlanta
I just bought a Raptor grill today, and Ford said they will install it for me… it wasn’t cheap however!
KRC
KRC
Karl
Diesel Technician
I live in Willis! I found the grille on Ebay and purchased it there!
KRC
KRC
Karl
Diesel Technician
I was unaware of this! I already purchased the harness, however I will keep this information handy for future reference!
KRC
KRC
Karl
Diesel Technician
It was multiple pieces, the letters have to be put on (which is actually handy if you want to paint them), the lights have to be mounted in, and a few clips and trim pieces have to be attached, all of the hardware needed was included though.
The original grille is undamaged save for one of the bottom clips because for some reason my license plate bracket was riveted on and cannot be removed without removing the rivets, which I did not want to do.
Yes, I still have all my fingers, I'm a diesel mechanic so I have a bunch of tools already and am no stranger to doing stuff like this.
Bruce
Bruce
Minnesota
Thanks ---
I have viewed Ford's parts list for the grille and it looks like there is a top piece, a middle piece and a bottom piece.
Not as easy as the Raptor grille we installed in our 2019. Did have a problem with one of the lower clips there which caused the first aid kit to be opened.
KRC
KRC
Karl
Diesel Technician
Thanks ---
The grille from the actual Raptor will not fit the other model Rangers, it is shaped different because the Raptors have a different bumper.
Bruce
Bruce
Minnesota
sorry, I should have said --- we installed a 2020 Raptor type grille in the 2019.
KRC
KRC
Karl
Diesel Technician
Looks great !
I was thinking the other day that with a Raptor style grill and some smooth oe style black fender flairs , maybe a set of Bronco SAS +30 offset rims 33” tires , and especially on a BAP Ranger it would be hard to tell them apart from a Raptor, especially at any sort of distance.
Ford Ranger Installed the Raptor style grille! 1772722335291-9
