Instrument cluster upgrade from 8" to 12"?
RangerDangerStranger
SF Bay Area
2024 XLT 4x4 in GreyBlue.
Cool Dude
Want to confirm, you have the 2.3L gas engine, the pictures are from your truck and you're in the US, correct?, Sorry if i made that assumption incorrectly. I'll assume you are, the 2.3L does not redline at 4500 rpms. the Lariot has the 12" screen, and will display the correct redline. If what i said above was correct, whoever configured the panel used the wrong engine type, the redline is set too low and the top scale should probaly be at least 7k RPMs. Good news is that all it should take is a few tweaks in forscan. the panel will/should have the correct display for your truck installed. Pic is what it shouild look loike. C~
https://www.caranddriver.com/photos/g43838990/2024-ford-ranger-revealed-gallery/?slide=9
Ford Ranger Instrument cluster upgrade from 8" to 12"? int1
joordan
Italy
ranger wildtrak 2023
Want to confirm, you have the 2.3L gas engine, the pictures are from your truck and you're in the US, correct?, Sorry if i made that assumption incorrectly. I'll assume you are, the 2.3L does not redline at 4500 rpms. the Lariot has the 12" screen, and will display the correct redline. If what i said above was correct, whoever configured the panel used the wrong engine type, the redline is set too low and the top scale should probaly be at least 7k RPMs. Good news is that all it should take is a few tweaks in forscan. the panel will/should have the correct display for your truck installed. C~
I am in EU and I have the V6 diesel wildtrak :)
vamosemonkey
Vinny
Dubai
Ford Ranger XLT 23L Turbo 4 Door 2024
Vagabond
How to get the bottom dashboard (lowers pic) on my ranger. I only get speedometer thats it. Something like this
Ford Ranger Instrument cluster upgrade from 8" to 12"? 1729428630149-zc
Ford Ranger Instrument cluster upgrade from 8" to 12"? 1729428480825-ll
joordan
Italy
If you read this thread from the start you will understand..what you have is the 8inch cluster, and you cannot have anything of the lower pic cluster cause that is a 12inch. You can only upgrade the entire cluster
vamosemonkey
Vinny
Dubai
Vagabond
Thanks a lot for the guidance.
Brent1982
Brent
Australia
Ranger RA 2022 XLT
Looks great. Was there a part number on the cluster before you installed it?
Sequoia
Dan
Germany
Ranger Wildtrak 2023
done, installed, upgraded. works like a charm, excellent upgrade!!do not know why ford does not give it as an optional at purchase...
one stupid question as I am new to the 12" cluster...the center display where all the different info pops up, it always needs to display something right?in the 8" it was always on demand
Awesome. Thanks for all the information. Where did you buy the 12” in the EU? I’d like to upgrade as well. What were the exact costs? One downside could be that the warranty is, of course, void. Thank you very much!
joordan
Italy
raranger
Sequoia
Dan
Germany
what is raranger?
Okay, I found it. €1500. How was it for you with customs, etc.? I also want to clarify whether the warranty (I have 8 years) is affected here in the EU. The text says it won’t be affected, but of course, that only applies to Ford Australia.
joordan
Italy
Do not see how the warranty could be affected, given if the cluster burn up you may get a replacement of the original 8”..
You pay VAT and import duty
diogomt
Brazil
🇧🇷 Ranger XLT
I ordered the new cluster...will post once the upgrade is done!
What's the part number for that 12" cluster?
