WarFries
- Thread starter
- #1
I have less than 700 miles on my 24 RR (US), and these are the issues I'm having so far:
I'm kind of... shocked by the issues I've had/am having with this truck so far. Especially compared to the experiences I've had with other new vehicles.
Here's a few other issues I've had and fixed that I didn't post above.
Neither of the keys from the fobs work in my glove box. Wrong glove box lock cylinder? Defective lock cylinder? - Upcoming appt. with dealership.Fixed by turning the key really hard, trying not to break it. Thanks to Parknas54.- It's been throwing a "Restraints Indicator Lamp Warning: The restraints control module has detected a fault with the passenger side air curtain circuit." Loose wire? Bad control module? - Upcoming appt. with dealership.
- It has a rough idle when sitting in park, even after warming up. It'll shudder intermittently and shake the passenger seat. It feels like it's trying to idle too low, or miss-firing. Sometimes it's subtle, sometimes it's worse. I don't hear anything at cold startup that may indicate cam phaser isssues... yet. This "normal?" - Upcoming appt. with dealership.
- Rough ride. It's like you're constantly running over cracks in the road, regardless of road type/quality. Feels like it's coming from the rear. Front end feels pretty smooth. I've had trucks with stock shocks that were rough in the rear, especially without weight, but it was just an amplification of road deformities (cracks, dips, etc). This feels like it's doing it on every surface type. Tire deformity? Just me? Here's a post that also seems to describe this: https://www.ranger6g.com/forum/thre...ularly-from-the-rear-tyres-out-of-round.8209/
- It doesn't feel like the shock damper modes change anything. Every time I cycle through the modes, I can never tell much of a difference, if any, both on and off road. I was in Off-Road mode on a dirt road, and at around 40mph I hit some small, washboardy pot holes. I was nearly bounced/vibrated into the ditch. It feels like the shocks are way too stiff all of the time, no matter what mode I'm in. I have the tires at 35 rear, 37 front (cold). I've also had them at 39 all around, and even 44 all around when I first picked it up. Tire pressure doesn't seem to make a difference. Maybe this is just me?
- Hood was hard to close, then impossible to close. Raised the hood latch as far up as it would go. And I had to twist the hood a bit to get it even on both sides.
- The RR button stop working and had to disconnect the battery. Hasn't happened since.
- The infotainment system crapped out once with some awful feedback noise from the speakers when switching menus. Had to turn the truck off and on again to fix that. Hasn't happened since.
