J-Braces required for a hard tonneau cover?
markal49
Mark
2024 Ranger XLT w/ FX4
Planner
I'm planning to had a hard, tri-fold tonneau cover to my XLT. I have no idea how much these things weigh. Am I going to need to add the J-braces to my bed?
Thanks.
Skitrem47
Albany, NY
Toyota 4 Runner TRD Pro
Teacher
Thanks.
I too have the same question as my tonneau is 4lbs heavier than the Ford recommended (anything over 88 lbs above the bed). I suppose it will be fine because you are not going to have the lateral movement you would if you had a cap on it.
James D
James
Sugar Land, TX
2025 Ranger Lariat, 2022 Jeep Compass
GManGeno
'24 Ranger Raptor
DevOps Engineer
Thanks.
Remember that even if your close but under you may consider the J-Braces anyway since static versus dynamic loads could put you over. This would be more of a concern if you intend to take it off road. Just something to consider.
markal49
markal49
Mark
Planner
The guidance from Ford doesn't say anything about that though. It just says required for anything above the rails that weights over 88 pounds. (never mind that this is all ridiculous to begin with).
I guess it's worth it as a precaution.
danmoochie
dan
florida
retired Sales manager
There is a FSA but only required for a full topper not bed covers. Free if you buy a topper from Ford. But no need for bed covers.
DanTheMan
Dan
Escape
Social Worker
This question is for anyone who has purchased and installed the J-Braces. Was thr part available from Ford? Or was it through a third part manufacturer?
I just called my local dealership parts department and they say Ford doesn't offer this part. This is in Canada, so maybe we are just behind?
markal49
markal49
Mark
Planner
You can order from Ford in the US, but I’m not sure if this is available to ship to Canada.
https://accessories.ford.com/ranger...ement-kit-for-non-raptor-models-vn1wz2627726a
Wayfaring Ranger
STL
I've said this before, but you will get 40,000 Ford Pass Points for buying your truck and that will make the J-Braces completely free to buy from the accessories website. The points end up being $200 worth and the braces are $170.
jrRaptor
Maize, KS
Yep! I used my points on Ford Accessories website to get the J-braces and the Lund Aeroskin 2 hood deflector and used 20% discount code so everything to my door ended up being $10. Still need to install them though.
Evilrider
Lloyd
Chester Va
2024 ranger raptor 2022 Explorer King Ranch
its paid for by Ford called my dealer he is checking it out.
jedadiah
Jed
Kentucky
I think they are also needed if you wan to run a rack above the bed. A bed cover by itself should be fine, but I installed a bed cover with slots for crossbars and pretty much anything I put up there will exceed the language limit listed with the braces. If they really are just for truck caps, then it's past time for that to be stated plainly.
I installed the J-braces just to be safe. I did purchase my cover and braces from Ford. Hopefully, if they ever decide covers with built in rack support should get J braces included, I can get reimbursed.
danmoochie
dan
florida
Great point. Let me check the bulletin again tomorrow.
